Question about Dishwashers
Dishwasher has light flashing and not doing anything.
  • daniel Oct 24, 2012
    what is that symbol, does/did it make noises, is it new to you or have you used it before, where did you get it and was it dropped or banged around a lot?
  • rooonee
    rooonee Oct 25, 2012
    is the door shut tight?
    Master:
  • 336 Answers
The switch that tells the unit that the door is shut is probably bad. That will prevent the dw from running. murf427
Posted on Oct 25, 2012
2 Suggested Answers
RixsFixes
  • 2200 Answers
SOURCE: lock on light flashing. Dishwasher will not do
Hi
This is a child lock feature to stop unwanted operation of the buttons. The usual way to cancel this on a Kenmore machine is to press and hold the "No heat dry" button for longer than 4 seconds. This should cancel the lock and resume normal function.
Hope this helps. Please do rate this answer. Thanks.
Posted on Aug 16, 2009
Key stuck on
Your description of the problem is a little vague.... What light(s) stay on? What light(s) flash? Is there a pattern to the flashing lights, in other words, does it blink so many times, then pauses, and repeats? Ir does it just blink steadily, continuously? And how about a model number or approximate age of your dishwasher?
Jan 09, 2012 | Kenmore Dishwashers
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Lock on light flashing. Dishwasher will not do
Hi
Aug 16, 2009 | Kenmore Dishwashers
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Diswasher will not do anything...
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Apr 21, 2008 | Kenmore 15919 Built-in Dishwasher
Dishwasher not draining and 3 lights are flashing
check this thread for starters http://www.fixya.com/support/t135923-dishwasher_beeping the solution to the leak would depend on where you think it is leaking from - usual areas to check are the door seal, door latch, inlet and drain hoses and where they connect, the base especially towards the back. also make sure the drain pipe the dishwasher is connected to is not blocked - sometimes leaks from in the machine can be traced to this cause. Hope this helps, post again if you find anything and hopefully we can help more :)
Dec 06, 2006 | Baumatic 24 in. BFD60SS Free-standing...
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
