Question about Hardware & Accessories
How do I install a t80 din bar timer
How to wire this in to the din bar
  • 5,245 Answers
Greenbrook T80 timer wiring appears on following link:
http://waterheatertimer.org/How-to-install-3-phase-timer.html#T80
Posted on Oct 25, 2012
How to program CLS Q 31 D TIMER
CLS Q 31 D timer is ordinary 50-60 Hz 24-hour din-rail analog timer; rated 15 amp, operating voltage 230v with power reserve and 30 minute time increments.
15 amp safe max is 12 amp x 230V = 2760 watts. Use line fuse to protect timer from overload. Use contactor for heavy-amp loads and 3-phase loads.
Copy following links for setting analog timers and wiring din rail timers
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
Add a comment and describe application for this timer
May 18, 2013 | Hardware & Accessories
TP8B16 digital timer instructions
1) Copy following links to identify timer and download possible manual, and see general wiring diagram:
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE22
2) Feb 2013. Add comment and describe timer voltage and include what you are controlling for additional help as needed.
Feb 23, 2013 | Hardware & Accessories
Greenbrook t80c din rail timer instructions
http://www.greenbrook.co.uk/pdf/T80-C.pdf
Jan 03, 2012 | Hardware & Accessories
HOW I INSTAL ,CONNECT SWITCH TIMER TE502 ? IT
Wiring diagram shows on side of timer and looks same as to following illustration:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
For more complicated illustration showing din rail and modular timer wiring variations:
http://waterheatertimer.org/images/NO-NC-timer.jpg
With din rail timers, the power connects to screw terminals 1 and 2 and this will run the clock and relay.
The TE502 image is bad, and I can't see wiring diagram exactly.
It appears that terminal 4 is common. This is typical for din rail timers.
Put Hot lead to terminal 4.
Terminal 3 appears to be the NO terminal, so put wire going to Load to terminal 3.
Jun 20, 2011 | Electrical Supplies
How to bypass mtd8
To permanently bypass the timer, you have to move wiring.
I don't have specific wiring diagram or programming manual for mtda8 timer, but am familiar with wiring din-rail mounted digital timers.
1) Wiring is typical across all din-rail timers, with variations of same theme depending on number of channels and purpose.
2) Open following illustration of wiring:
http://waterheatertimer.org/images/DIN-series-wiring-300.jpg
Same-similar illustration shows on side of timer.
3) Notice the mtda8 has 5 screw terminals.
4) Two screws are for incoming power. These terminals are usually labeled 1 and 2. These wires power the timer.
5) Three more screws are for the timing relay. These screws are usually labeled 3 4 and 5.
Typically the #4 center screw is common, and carries power. And when timer is ON, power is live between #4 and #3 terminal. When timer is OFF, power is live between #4 and #5 terminal.
6) Move #3 wire to #4 or #5 screw and then the timer function is bypassed.
Jun 15, 2011 | Hardware & Accessories
1980 Yamaha Townmate T80 wiring diagram
Hi, Jbrown5050 for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1980 Yamaha Townmate T80 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha Motorcycle Manuals
OEM parts for Yamaha
HAYNES MANUAL Yamaha T50 T80 Townmate 1983 95 eBay
Mar 07, 2011 | Yamaha Motorcycles
Hi my dry had a broken timer knob and the dryer would work if I pushed the knob I got a replacement part but dont know how to rewire it agen and the part looks different the old one had T80 on it but this...
Your timer switch should come with a wiring diagram.
Check with the supply house you got the timer from and let them make sure you have the right part for your model dryer.
Sometimes the new timer will be different, that is where the wiring diagram comes into play.
I hope this helps
Oct 01, 2009 | Fisher and Paykel Dryers
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
