Sub woofer is not working. it has orange flashing light at the back
    Scholar:
  • 106 Answers
Look at the connection of the sub woofer. The orange light indicates either there is some problem with the wire or the connector at the end of the wire.
Also make sure the pin or hole where you insert the sub woofer is working perfectly. You can simply check it by placing another sub woofer at that vary spot and see if it is working fine. If the hole is fine then the problem is either with your cord or your wire pin.
Posted on Oct 24, 2012
hawkwatcher
  • 67 Answers
SOURCE: sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Posted on Jan 10, 2008
SOURCE: teac AG D8900 II sub woofer not working
click on the blue "teac sub woofer" link top of page, solution is in my response to another with same problem-that is at least 3 of us with this now.
JS
Posted on Apr 16, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: What kind of sub woofer
is this receiver for surround sound tv or audio (?) can your rec put out up to 100 watts (?) if so I am suggesting this sub woofer
  • http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&XID=O:saw2500:dg_ggldf&productId=8198552921665089844#specifications
note..for future references always tell the brand/model of item in question, to insure better and hopefully quality help..
this is where you can purchase plus look at other sub woofer
  • http://www.bestbuy.com/site/olstemplatemapper.jsp?_dyncharset=ISO-8859-1&_dynSessConf=8718092490643603783&id=pcat17071&type=page&ks=960&st=sub+woofer&sc=Global&cp=1&sp=&qp=crootcategoryid%23%23-1%23%23-1~~q73756220776f6f666572~~ncabcat0200000%23%234%23%232a&list=y&usc=All+Categories&nrp=15&iht=n
Posted on Aug 18, 2010
SOURCE: Onkyo -TX SR604 sub woofer
change the capacitors on the audio board
Posted on Feb 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: power sub woofer is not
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Posted on Jun 13, 2011
The sub-woofer seems to have stopped working.
yup it stopped working,guess its time to get a new one
Apr 21, 2015 | Durabrand HT-3917 Home theater System
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
Hello, my Harman Kardon HKTS 15 sub woofer don'st work, the light that suppouse to turn from orange to withe when i turn on my receiver stay orange.could be the cable from my receiver to the sub...
It could be because of your subwoofer AMP is gone.
Temp fix: Disconnect the subwoofer wire from receiver for 20-30mins and plug-it back. It did work for couple of months.
Aug 22, 2011 | Harman Kardon Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Sub woofer flashing red and green
sir,,i think there is something wrong with the connections or the cross over,,,kindly check it out or mjaybe the cone of ur speaker is damage,,,hope too help you thnkss??
Jan 27, 2008 | Kenwood SW36HT Subwoofer
 Grubhead
Grubhead
