Question about Kenwood KDC-128 CD Player
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back had blown and the audio fuse in my car fuse box had blown. I have changed the fuses and tried connecting the wires again but nothings worked........do I need to get the radio replaced? I drive a 99 Peugeot 306 van.
    Problem Solver:
  • 12 Answers
You need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Posted on Jan 02, 2009
How can I program the kenwood kdc252u to turn on and off with the ignition? As of now the unit stays on after I turn the vehicle off, or stays off after I turn it on.
you have wires crossed or not hook up ignition switch for radio stereo power wire connects to cars ignition.stereo memory (yellow or orange wire) connects to constant power for radios memory(rad stations /clock)
Feb 26, 2014 | Kenwood KDC-252U
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
Firstly, the main wires from the KDC-128 you need to check are:
RED - this should be connected to the vehicle's +12v IGNITION wire.
YELLOW - this should be connected to the vehicle's =12v BATTERY wire.
EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).
Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.
Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Jan 12, 2013 | Kenwood KDC-128 CD Player
Every time i turn my unit on i have to turn demo off. Why wont it stay off?
Is your clock keeping the right time? Are your radio presets retaining their memory?
Jul 24, 2011 | Kenwood Kdc-mp745u
How to unlock the stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Apr 27, 2010 | Kenwood KDC-MP435U CD Player
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Stop kenwood KDC-mp239 loosing radio settings with ignition off
You have two power leads bringing battery power into the radio. One is switched off when the ignition is off and the other power lead is always on. That second one is the one you may have wired wrong. You need to check that one out to make sure it stays on when the key is turned off. Good luck.
Nov 11, 2008 | Car Audio & Video
Kenwood kdc-128
The remote lead on the back of the radio should be a blue wire with a white stripe. If this wire is not present, then you can use an accessory lead in the car or the accessory lead (red) at the radio harness. Hope this is helpful.
Sep 14, 2008 | Kenwood KDC-128 CD Player
Im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
Jun 21, 2008 | Kenwood KDC-128 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
Kenwood KDC-128 CD Player Logo
253 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
