Payne Gas Pack Furnace A/C and Heat Unit
Nothing functions on the unit not the a/c nor the heater, I've replaced the tstat,spark ignition module with the gas valve,the contacter, and the step down transformer. It does'nt have a circuit board so there is no led's blinking. And if this helps any the Model # 585HJ024040
  • 61 Answers
Do you have power to the unit?
Is it a 110v or a 220v unit?
check your power supply.
Posted on Jan 02, 2009
Payne gas fired forced air furnaces,model 394gad, replaced transformer was shorted out,and blower motor , started throwing sparks,also the capacitor was five bucks.
for somebody to jump the fuse it tells me there is a low voltage wiring problem. likely have a bad tstat wire somewhere. blower not turning on in auto usually means you have a G wire hooked up to the tstat and the tstat is set for gas heat, needs to be set to electric heat when G wire in place. there's a good start, NEW TSTAT WIRE and proper settings
Dec 22, 2017 | Heating & Cooling
Furnace will not light it has an electronic ignition gas does start but igniter doesn't heat up how can I check to see if that's the problem or could there be another problem the furnace is a philco
Sounds like the ignition is not working, you should probably get a new unit, or get a new ignition module. Depending on price of new module and ability to change it. Or maybe your just out of fuel.
Apr 17, 2014 | Heating & Cooling
No spark. My HSU75NG MR. Heater (Big Maxx) will not start on its own. It purges fine ,calls for heat fine, gas flows fine; BUT there is no spark from the Electrode Igniter. Which I have replaced. The
The capacitor in that unit is for starting the motor that drives the blower fan. It has no impact on the ignition of the gas burner. On the control board, there is a light that should be flashing, can you tell us how many times it is flashing?
Feb 18, 2014 | Mr. Heater Natural Gas Garage Heater -...
When i turn the heat up sometimes it takes a long time for the gas furnace to start ..why?
Watch your furnace when you turn the thermostat up...make sure to record everything that it is doing. If you have an induced draft, forced air system, then the heat sequence of order should go like this... Initial call for heat from tstat, Inducer vent motor turns on-pulls in the pressure switch, circuit board sends power to igniter whether it is spark or hot surface, then gas valve opens. Flame sensor senses flame, burner stays on, and blower motor kicks in to heat the space. If you notice any variance from this, then something needs to be checked by an HVAC Service Tech.
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
Lennox gas furnace G21Q4/5-100-1 sometimes won't kick on
Hi check out the flame senser is clean also jump ou tthe pressure switch see if it lights when you do this , igntion modul is just a box with some push on wires just get the right one the info is all on the module
Feb 16, 2010 | Heating & Cooling
Furnace will not start. a/c seems to work ok. i
HI; I need more info. How old is the equipment. name brand of equipment. Also to answer Your question ...Yes the tstat wire goes into the furnace to make several connections then a seperate cable(brown) will follow Your freon lines out to the condensor.Also try removing the cover and have a good light. Get someone to turn on heat at tstat and watch for clicking sound.Sounds like You have a spark assist pilot system. When the sparking starts the pilot light should come on. Then once the pilot sensor feels the heat comming from pilot light it will allow the gas valve to come on...BE CAREFULL...I ASSUME NO RESPONSABILITY FOR YOUR ACTIONS...alpharome416 PS.usually there is nothing to worry about just keep Your space to begin with ok.
Feb 09, 2010 | Dometic Rooftop RV Air Conditioner
RUUD 90 Nat Gas unit, >15 yrs old. T-stat calls for heat, nothing happens. I can place the fan in manual ON, & after a few mins. the warm air starts to circulate. If I leave the fan in auto, the...
sounds like you shorted out the heat anticipator in the tstat. try jumping red to white at the tstat wiring terminal and have a friend stand near the furnace to see if it cranks up immediately. if it does the problem is more than likely in your tstat. be sure to blow out any dust in the workings of your tstat. this is 24 volts and shouldn't hurt you but try not to short it out to the common or other wires.
Nov 24, 2009 | Heating & Cooling
Heating problem
the tstat sounds like it is not connecting the white and red terminals which is usually the heat cycle if it is a gas furnace if so to check I take tstat cover off and jump white terminal to red terminal this is the standard heat position the unit should fire the heat cycle if not a gas funace let me know what type of unit you have hope this helps
Jan 11, 2009 | Heating & Cooling
I'm working on a Payne gas pack furnace heater and a/c unit. I replaced the tstat cause the a/c worked but not the heat,also replaced the spark ignition module with gas valve,the transformer, and the...
pull the fuses and check voltage line to line with the fuses out you should have 208 to 240 volts if you have 50 or so volts try line to ground if you have 120 on one leg it will back feed with the fuses in,because of the windings involved. in any case you are missing one leg somewhere to get the voltage readings that you have poasted
Jan 02, 2009 | Heating & Cooling
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
455 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
