Question about TCL 24 in. Hdtv
I accidently preesed some button and after that only blue screen is coming and at top right of the tv VIDEO is written. Remote is not working also
The remote accidently has S video button pushed. I have S Video at the top of a blck TV screen. I'm not sure how to get back to the TV screen because no button is working. I run the TV through the...
Use your TV remote to change the input away from S Video. There should be an Input button or Video Source button. Press this button repeatedly to cycle through the inputs. Depending on how your cable box is hooked up to your tv, your input will vary.
Jul 18, 2011 | Vivitek Televison & Video
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
I accidently sat on remote for centrex t.v now all i have is a blue screen and a red padlock sign, how do i unlock
pls check hideen key on remot cantrol
try digit key [- - -] preesing 3 to 5 sec. and see key lock is off than re set preesing 3 to 5 sec and see on the screen tuning lock is off
or
lock key on remot cantrol pls. press 5 to 10 sec.and see the screen red padlock is opan or green then try remot cantroll any function use normaly
Oct 26, 2009 | Televison & Video
I have a 57x500 Hitachi ultravision digital t,v,.....When we try to watch DVD Movies or vhs,the screen has the dark side bars on the side,,how do adjust the screen to make the movies fit on the screen so...
On your remote there should be a button that says "Aspect" or "Pic Size". Press thisuntil the video fills the screen. If you do not have the remote of don't have the original remote, this setting can be found by preesing the menu button on the tv, go down to video settings and it should be listed under "Aspect Ratio", change it untill the video fills the screen.
Dec 30, 2008 | Hitachi 57F500 57" Rear Projection...
How to unlock the parental control on Advent Q1435A
I'm having the exact same problem with the same TV right now, would love to know how you fixed it as I've lost the user guide. Thanks
Dec 02, 2008 | Televison & Video
All Ihaveis blue screen
You need to change the source (original remote) or the input (univeral remote). It needs to be in TV mode - not video.
Aug 30, 2008 | Sanyo DS31520 31" TV
Vizio L37
try to go to the menu,then find the words,blue on or off,turn it off,then you will see the changers.
Nov 10, 2007 | Vizio GV42L 42 in. LCD Television
Vizio L37
you probably changed the input mode.
Nov 10, 2007 | Vizio L37 Television
Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
Sep 23, 2007 | Sanyo AVM-3659S 36" TV
TCL 24 in. Hdtv Logo
117 people viewed this question
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
Tom Chichester
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
