Question about Samsung SGH-x475
Cell phone in water
I drop my cell phone in water it still works but the battery wont stay charged and it give me the message of leaving the service area and entering the service area both will came up one after the other even if standing still calls get disconnect alot to
    Problem Solver:
  • 9 Answers
WELL THE WIRES WHERE THE BATTERY CONNECTS UP WILL BE BROKEN (NO POWER GOING THROUGH THEM) SO INFORTUNATELY IT IS BROKEN !
Posted on May 31, 2007
I dropped my phone in water. It stayed in for no more then 10 seconds. Now when I try to charge it, a green light in the upper left corner came on . So I unplugged it and reconnected the charger. No l
DO NOT SWITCH A WET PHONE ON .
If possible take the battery and SDCard / SIM Card out.
Place in a warm area such as an Airing cupboard laying ontop of a bowl of cooking Rice. Leave for about 2 days as the rice will draw out the water naturally.
Or put ontop of a dry towel ontop of a radiator . Do not let the phone sit directly on the radiator or it may ruin the plastic on the phone.
Jan 24, 2015 | Cell Phones
Tip
How to fix a phone that dropped into water
Hi, when ever a phone drops inside the water, First you will need to remove the battery from the cell phone.If the battery is left inside the cell phone, the water will damage the cells inside the battery, why?, because there is still Power inside the cell phone that can damage the battery cell.
To service the phone,you will need to unscrew the cell phone,because has entered into the cell phone and it can damage IC chips inside the cell phone if not attended to immediately.
Use a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.(depends on the type of phones)
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone. battery might be dead or low in power..Better you can have a spare battery around
after servicing the cell phone..
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
That's solves your problem.
on Sep 15, 2011 | Cell Phones
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
Battery wont charge
I had the same problem a few days ago. this could be because the battery is not connected to the cell phone properly (from dropping it or leaving the cell phone in the sun) and may need something, such as tissue paper or ordinary paper to be folded and put on the one side of the battery which is not connected and this will tighten the connection.
hope this helps
Feb 23, 2012 | Apple Iphone 2g 3g 3gs 8gb 16gb S
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
I droped my voyager in water
HI,
PLEASE USE HAIR DRYER TO DRY IT AND DONT CHARGE OR SWITCH IT ON FOR A DAY....................................
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Keeps entering and leave service area
you need to replace the circuit board or if possible replace the micro antena located on the circuit bored so i suggest u find yout nearest cell tech. and have it checked out and replaced
Jun 15, 2009 | Samsung SCH-a930 Cellular Phone
Cell phone will not turn on when only using battery power
Have you tried leaving it over night plugged and on and see if that helps? If u pulled it out of the water quickly, that might do the trick.
Mar 09, 2009 | Samsung SGH-a437 Cellular Phone
I drop my phone centro palm into water! I charge the phone and the red light turns on but my phone wont turn on at all. What can i do
Get a bowl of rice. Remove the battery from the phone. Leave the phone back open. Put phone and battery in the bowl of rice, cover and leave overnight.
The rice will hopefully soak up any water inside the phone and battery. If this doesn't work there may be permanent damage to the phone from the water and charging afterwords.
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Phone wont charge
Did you drop your phone in water? or do you live in a humid area?
Your phone was exposed to moisture. That red dot is a moisture sensitive piece of tape that changes colors when it gets wet.
If your phone still works, but the battery won't charge when connected to a home charger, you might try charging it in your car. Its a different type of current and may work with a somewhat damaged battery.
If that fails to fix the problem you may need to get a new battery.
Hope this helps
Jan 15, 2008 | Motorola Mobility RAZR V3
Samsung SGH-x475 Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
