Question about Indesit DF125 24 in. Built-in Dishwasher
Indesit IDF125 no power have checked fuse
No power lights etc.. have checked fuse door etc..
Water has stopped heating up on indesit idf125
Heating element or temperature sensor failure
Aug 22, 2017 | Indesit Washing Machines
1999 Lincoln Town Car- Courtesy Lights will not come on but all other lights do- THIS GIRL NEEDS HELP!
There are two fuse boxE's, one in the engine bay and one under the dash. Did you check both?
May 19, 2015 | 1999 Lincoln Town Car
IS 200 wont start, no dash lights, no radio,
You should have power to the dash if the key switch is working.
The main fuse would kill everything in the car.
Depending on how it happened, I would check the fuses and then check for voltage at the key switch.
Aug 13, 2012 | 2005 Lexus IS 200
How do I remove the side panal on my idf125
All pump components are at the bottom of the machine - removing the side is of no use to you.
Turn machine on side and you will find a plastic cover that can be prized off carefully with a flat blade screw driver. The cover also houses a sensor, so take care when removing it and carefully remove the connecting wire.
You now have access to the pumps and heater etc.
Take care
Jul 09, 2012 | Indesit DF125 24 in. Built-in Dishwasher
Indesit DF125 24 in. Built-in Dishwasher Logo
94 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
