Question about Safety 1st Baby Care
How to dismantle safety1st secure lock bed rail
How do I change out the batteries in a Safety First nodaway?
The battery compartment is secured to the bottom of the bassinet. Remove the baskets from the fabric shelf (if present) and look between the frame rails. The battery compartment has two covers, each secured by a Philips screws (one on each side of the compartment). Unscrew the screws and you'll see 2 AA batteries in each section. Match the orientation of the batteries when you replace them. Then replace the covers and their screws. Then put back the baskets.
The instructions for the Nod-A-Way Bassinet are available from the manufacturer: http://safety1st.djgusa.com/en/djgusa/nod-a-way-trade%3B-bassinet-bt044awu--1 . The direct link to the manual is http://safety1st.djgusa.com/product_instructions/en/BT044_inst_ES_030612.pdf .
I hope this helps.
Oct 11, 2014 | Safety 1st Baby Care
Kincaid Carriage House Sleigh Bed side rail split
This can happen if the bed is not securely fastened together. The headboard/footboard shouldn't be able to shake without moving whole bed.if they do the joints will fatigue and fail from everyday wear and tear weight probably not a factor as the stressor would be vibration of loose joints not weight stress. Is this common? Depends on design. Bed frames that screw tight it is common.frames that snap together not so much as there is nothing to tighten. design flaw seems more possible in that circumstance.
Dec 01, 2013 | Kincaid Carriage House Sleigh Bed
I have the Ellis 4 in 1 and I am ready to make it a full bed, but I can not find the bed rails.
You can use about any full size bed rails you wish. They may need a little fitting but if you are looking for actual Ellis 4 in 1 bed rails here is a place that sells them http://www.babylox.com/simplicity/ellis-full-size-bed-rails-espresso225893.php Ellis no longer makes them rails themselves, they were discontinued.
Mar 22, 2011 | Toys
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
I need a plastic part for a Nelson baby bed, that holds the rail
I need the pieces to go on the sides of the baby bed that lets the bed up and down.
Could you please let me know where I can go to get the parts for this>>??
Thanks,
Mary Adams
1474 Swindall Road
Troy, Alabama 36081
334-566-2900
Apr 11, 2009 | Baby Gear
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Crib locks
if you're missing the lock parts from the ends of the side rails(end caps), I was to. I borrowed the cap from the youth bed rail
since when it's configured as a crib, that rail is extra anyway.
when it was time to go with the youth bed I simply put the end
caps back onto the other rail. GOOD LUCK!
Apr 10, 2008 | Childesigns Carrollton Crib
Baby Care Logo
57 people viewed this question
Top Safety 1st Baby Care Experts
Dorel UK
Dorel UK
masud
masud
Are you a Safety 1st Baby Care Expert? Answer questions, earn points and help others
