Question about Belling Microwave Ovens
Microve works but turntable comes & gos
Sometimes turntable works sometimes it doesnt
  • Belling Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is intermittent or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can contact Belling customer service for more help.
Posted on Jan 03, 2009
How do I repair turntable
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 17, 2014 | LG LMHM2237ST LMHM2237ST 30" 2.2 Cu. Ft....
Why is turntable skipping after motor replacement?
It doesnt matter which way it is plugged in. If the microwave has a guide roller (ring with 3 wheels), check the wheels to see it they are all intact and roll smoothly.
Jul 15, 2014 | Microwave Ovens
Microwave wont work
Call the manufacturer about resetting the electronics. If not possible the board needs to be replaced if the price is right.
check here Search Over 2 1 Million Appliance Parts
Sep 08, 2017 | Sharp Microwave Ovens
Microve turns on, but will not heat Model number is FMT148G1B2 Everything seems to work except there's no heat. Clock works, countdown timer, light, turntable, etc., just no heat.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Apr 16, 2009 | Frigidaire FMT148G1 Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Microvent is coming loose on the bottom of mounting.
Generally, these units are held to a backing plate with a pair of screws that are accessed by removing the vent plate above the door. There are a couple of Philips screws. each end, there is a slot head screw head on a rod. Support the unit and back these screws out. The unit will then pivot from the bottom away from the wall. Detach it and then repair the issues with the hold bracket. Warning: these units are heavy!
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Light and fan on microve will not work, the microwave works finr
there may be a fuse that controlls them internally or the relay that switches them on is not functioning
Nov 26, 2008 | Microwave Ovens
When you hit Start to cook, do the inside light and turntable come on? Yes
Any unusual noises? No
Is it louder or quieter than usual? No change
Sep 14, 2008 | Microwave Ovens
Microwave MS-2645DPA... won't heat food. otherwise works, lights on, turntable working, but nothing heats at all.
tell me about it. try not to buy ge. the sevice charge was almost 200$. it still doesnt work. it has been over 30 days. so they want me to give them another 79$ just to come out again
May 31, 2008 | Microwave Ovens
Microwave Ovens Logo
182 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
