TV Freeview and DVR set up
My friend has the following kit: Bush TV LCD32TV005HD5 Television (2 scarts + RF in and out) Icecrypt T5000 Freeview box (2 scarts + RF in and out) Panasonic QMR-E55EB/EBL DVD Recorder (2 scarts + RF in and out) She receives her TV signal through the aerial. We've tried every way we can think of to set it up and although she can watch Freeview channels (currently on AV1) or watch a DVD played on the recorder (currently on AV2), we can't find a way to get the Freeview box and DVD recorder to 'talk' to each other so that Freeview programmes can be recorded. Any ideas please?
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Connecting up CRT TV, VCR, DVDR and digital box
With the indulgence of Mrvica, it would seem you posted the same concern twice. Here is a link to your other post with responses from xx and this responder.
Hope this be of help/idea. Pls post again should you need additional information.
Good luck and kind regards.
Posted on Jan 31, 2008
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
What plugs in where at the back of model 32AV633D Does single scart go to ext 1 or ext 2 Where does outside aerial plug in, there are so many ? Sorry but I'm a complete technophobe who is hopeless at...
If you have a cable box or freeview box, your main aerial lead plugs into the box. Then you connect a scart lead from your cable box/freeview box/ or dvr box to ext 1 on the tv. Where the aerial lead plugs into your cable/freeview/dvr box, there may be an aerial out socket too. You could connect a patch lead from the box to your tv as well so you have UHF direcy from your cable/freeview/dvr box to the TV as well as scart
Aug 06, 2009 | Televison & Video
Do not understand how to set up my alba digi box to my television and recieve basic digital channels help!
Hi.
Ok
1) plug aerial in to the antena in sock on freeview box.
2) plug short aerial type lead in to rf out socket on freeview & antena in socket on TV.
3) plug A scart lead in to the socket marked TV on freeview box & the other end of scart in to one of the scart sockets on the TV.
If your TV has more than one socket plug it into the one marked AV1 or AV2.
4) plug in freeview to mains electricity & switch box on.
5) Turn TV on freeview should appear automatically if it doesnt look on your TV remote for A button marked AV or a button with either A circle or square with an arrow going through it you may need to press this several times until you see digi picture come up.
Thats basically it but do check that you dont need a new aerial etc to be able to get digi signal in your area.
http://dysonmanuals.llc.nu/
Jul 26, 2008 | Televison & Video
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
