Question about Sony VAIO VGN-NW350F/S Notebook
Touchpad not working
Dont want to bye whole new pad or is there no more options
  • Lastoni Wibowo Oct 25, 2012
    first of all try to reinstall touchpad driver, if this not work, buy new touchpadihope this will helpthank you
    Problem Solver:
  • 9 Answers
Buy a mouse, it's cheaper and more reliable.
Posted on Aug 20, 2013
Flases f 21 code worked fine untill i put new front board in and i cleaned out lines and hose still giving f 21
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad.
Apr 01, 2011 | Maytag EPIC MFW9600S
My mouse pad in my computer wont work when i tap it
It will depend on what touch pad (and related software) is installed on the particular computer, but you will find the tap option under the Control Panel. Open your control panel, select "Mouse" There will be a TAB in the mouse properties called "touchpad" (surprise, surprise!) where you can toggle tapping on/off.
Hope this helps. PS: if you DONT see the touchpad option - you will first need to install the drivers/software for your touchpad. Most HP touchpads are the Synaptics Touch Pads - Find the drivers here: --> Click here!
Feb 07, 2011 | HP Computers & Internet
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
Jan 16, 2010 | HP Pavilion Dv3-1075us Notebook
The left key on my dell touchpad is not working
that part of the touch pad is not working anymore, its faulty and you need to replace the whole touch pad.
I don't know why this is mostly common with Dell. My friend has a Dell inspirion 1501 and the touch pad has exactly the same problem as yours.
I would advice you get a USB mouse to keep you going pending the time you get the touch pad fixed.
I wish you the best of luck.
Jan 06, 2010 | Dell F3534 Touchpad
The "mouse" pad on my Acer Aspire 5920 laptop has suddenly stopped working. What can I do to mend it
You can try pressing the Fn + F7 key to activate it, if that does not help you can check in the BIOS if the touchpad is disabled.
Thank you for choosing Fixya
Nov 11, 2009 | Acer Aspire 5920-6727 Notebook
My touchpad is not working
install the tachped dirver in laptop and
check it ........and 2nd option is remove the touch pad and install new one more info www.compudesk.in
Mar 28, 2009 | Compaq (153515-001) Touch Pad
How i can stop work of my touch pad
Hi Sanju,
Follow the below steps.
1) Goto Start
2) Click on Control Panel
3) In the control panel, You will find the icon of Mouse
4) Double click on Mouse icon and a new window opens up.
5) click on the Others option in the window. In this window, You will have option to disable the touch pad.
6) After unchecking this option, Press Apply button and OK the change.
This should do the trick !
Rate the solution as Fixya !
Tnx,
AD
Mar 03, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
Touch Pad
In the touchpad settings (Control Panel, Mouse) see if tap to click is enabled, if so uncheck and see if there is any difference. Also try booting in the safe mode, and see if that changes anything (F8 during boot to access safe mode) If no difference, then you'll likely need a new palmrest to fix the touchpad. If the touchpad works normally in the safe mode, try a new touchpad driver from support.dell.com
May 05, 2008 | Dell Inspiron 1501 Notebook
Sony VAIO VGN-NW350F/S Notebook Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
