Question about Slendertone Abdominal Muscle Toner
Error e002 slendertone flex belt
Error e002
    New Friend:
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Posted on Jan 19, 2013
  • KAREN GREENSIDES Jan 23, 2013
    as it was 4 years old i did not get it fixed i bought a new one.
    New Friend:
  • 4 Answers
The cables that Connect the pins on the other side gets breaked, i Fix it, i replace the pins With bolts, now it work like a charm, see the all steps that i do...
https://drive.google.com/folder/d/0B6C5lV38JRuhUVdzNUdvVTZSWEk/edit
Posted on Jan 10, 2015
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
I want to watch the get started video on The Flex Belt, How to get started.
Flex Belt - YouTube
? 8:16
https://www.youtube.com/watch?v=gBYvxDeb5VY
Jun 28, 2013 - Uploaded by flexbeltabbelt
We've created helpful videos that will walk you through the easy set-up process. It is very simple to set up The Flex Belt and only takes a couple of minutes... ... tips for awesome results and help you with any questions you may have. ... Getting Started with your Flex Belt - Duration: 8:08. by flexbeltabbelt ...
The Flex Belt video review - YouTube
Dec 08, 2015 | Slendertone Flex Pro Abdominal Muscle...
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Aug 13, 2011 | Slendertone Fortex
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
May 21, 2011 | Health & Beauty
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Jan 13, 2010 | Slendertone Fortex
Cannon MF8180c - E002
Go to this link. Type "error E002" in the search window and click Search. Select the System Error E002 link and you will see some things to try to resolve the problem. If it persists, you may need to have the unit serviced.
May 22, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Slendertone Abdominal Muscle Toner Logo
4,330 people viewed this question
Top Slendertone Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
