HP DesignJet 750c plus 010032 00070B17 - Office Equipment & Supplies
SOURCE: HP DesignJet 750C
Yes, I had the problem a week ago, it was a "Doooh" moment when I figured it out.
Your cutter is not where it is supposed to be. It should be OUTSIDE of the metal strip, and you almost certainly have it running in the groove on the inside. THe cutter wheel should have almost 1/2" overlap with the overdrive blade.
As the service manual says on reinstalling it "Ensure the cutter is over the overdrive blade".
I must have looked at it 10 times before it registered. THere is even a drawing. Not a clear one, until after you realize what is wrong.
Posted on Sep 16, 2008
antiochpc
  • 1314 Answers
SOURCE: error code 070020
From the service manual:
070020
One of the Drop Detection errors has occured - or, during the Drop Detection no drop was detected.
Pen checking is set to OFF.
Corrective actions:
1. Perform the drop detect calibration
2. Troubleshoot the cartridges and the drop detector
3. If required, replace the service station
4. Check the cable assembly and the main PCA.
If you are inclined, I can upload the service manual for you which tells you how to enter the service mode and perform the drop detect calibration. Warning: If this is done incorrectly, it could render your machine useless so if you are not inclined to do so, hire a professional to do it. Otherwise let me know and I will upload the manual for you.
Posted on Feb 18, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
  • 76 Answers
SOURCE: Cannot find MAC address for DesignJet 750c Plus
check your printer's menu settings you find menu for network settings there you can find ip addreses and MAC ADDRESES.
Posted on Aug 21, 2009
  • 357 Answers
SOURCE: everytime I turn on the designjet 750c plus, it
Make sure you have the correct cartridges and that the tape has been removed.
You can try a new set of cartridges and see if that solves your problem.
I hope this helps.
Have a good day and good luck.
Posted on Nov 20, 2009
ERROR VIA PAPER HP DESIGNJET 750C PLUS
check with HP printer information by model #.
Jul 31, 2014 | HP DesignJet 750c plus InkJet Printer
Tip
Download Service manul for HP DesignJet 700, 750C, 755CM plus
Hello,<br /><br />Simple click on the below link and you will find the service manual for HP DesignJet 700, 750C, 755CM plus<br /><br />This manual is in PDF format and because of its volume, it might take some time for the manual to load completely. How fast the manual will open shall be determined by your system speed/configuration<br /><br /><a href="http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%20700,%20750C,%20750CT,%20755CM%20Service%20Manual.pdf">http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%20700,%20750C,%20750CT,%20755CM%20Service%20Manual.pdf</a><br /><br /><span>The manual might take some time to load completely because its large. So you have to be a bit patient for it to load.<br /><br /></span>I hope this is helpful to those interested in this service manual.<br /><br />Good luck.
on Feb 22, 2011 | Office Equipment & Supplies
Hp 750c Designjet plotter system error 010030 00070b20
This is a problem with one of three
  • Trailing cable
  • main PCA
  • carriage assembly
Jul 09, 2012 | HP DesignJet 750c plus InkJet Printer
Cannot find driver for my 750c for windows 7 how can l install my 750c to windows 7
There are free software you can download for this designjet 750c by finding at websearch like yahoo.com or msn.com. Just type the driver name for this printer and you can download it for free. Most of the printer driver now can be downloaded online with free cd key. Just let it try. or Maybe the printer you are installing is not compatible with windows 7. try to read you printer's user manual.
Nov 11, 2010 | HP DesignJet 750c plus InkJet Printer
Aug 21, 2009 | HP DesignJet 750c plus InkJet Printer
DesignJet 750c Plus System Error 040502
The bad news is that this seems to be a fatal error of the main board. The only time I have had a similar error is when the carrage motor shorted out and blew the main board. This probably did not happen in your case but something appears to have taken the board out. The main board is speculation, but I think I am correct, sorry, Dave
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
Hp 750c plus System error 060309
Please take a look at this link and follow the instructions given there. Also relevant links here and here.
Hope that helps you to sort it out!
May 22, 2009 | HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Error on display
either bad carriage or trailing cable if you've already tried new inks.
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
107 people viewed this question
k24674
jasbo
jasbo
