Question about Behringer XENYX X1204USB/1204 USB 12-Channel Mixer
Owners manual for Behringer xenyx 1204 USB - Behringer XENYX X1204USB/1204 USB 12-Channel Mixer
  • bryan_deem
    bryan_deem Nov 06, 2012
    Yes I found this very helpful. I have now sorted the problem out.
  • Cindy Wells Nov 06, 2012
    You're welcome. Cindy Wells
  • 5,475 Answers
Behringer has the documentation for the Xenyx X1204 USB Mixer on the product page: http://www.behringer.com/EN/Products/X1204USB.aspx . See the drop-down menu labeled Documentation on the left side of the page; it's below the list of stores that sell the unit. The owner's manual is at the bottom of the list in that menu.
The file is a PDF so you will need Adobe Reader or a similar program to display the 3.1 MB file.
I hope this helps.
Posted on Oct 24, 2012
2 Suggested Answers
SOURCE: I have a problem with my Behringer mixer xenyx
Is the XLR unplugged from the channel when you are using a 1/4 " instrument cable?
Posted on Feb 12, 2010
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
How do I get driver updates to connect with pre sonus software
Not sure what your issue is, as long as you have the ASIO drivers installed you'll be able to get a decent copy of the main mix into and out of presonus. Even if not the standard windows sound drivers will recognise it as an external sound card and you can map this into / out of presonus so you don't actually need ANY drivers other than standard windows ones. If you were hoping to get access to the individual channels to do the mix in presonus forget it, this is not what what your mixer is designed for, get an X32 or other professional mixer.
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
I need driver update to connect with pre sonus artist one software
If you use the Behringer ASIO drivers (available from their web site) it will connect just fine, you should also be able to use the sound card drivers that came with the computer as they should pick up on the mixer (assuming it is a USB version) but you do not say if you have a Mac, PC or what operating system you are running so it is impossible to be precise
What causes my cd/tape input doesn't work anymore.
Make sure that the cable going to the left and right inputs is OK. Try another cable or test with a different recorder.
Oct 01, 2014 | Behringer XENyX 1204 XENyX 1204 12 Channel...
Behringer How To Use x1832 usb mixer
What is your question? A bit more information is needed before we can answer your question???
or
Read the manual: http://www.behringer.com/assets/X1622USB_X1832USB_X2222USB_X2442USB_M_EN.pdf
Aug 09, 2013 | Behringer XENYX X1832 USB Mixer
The cd with behringer for w xp i wanna install cd for w7
You can download suitable drivers from Behringer's site. Are you using the 32- or 64-bit version of Windows 7?
BEHRINGER Control Downloads
Once you've done that:
  • Uninstall the existing Xenyx drivers.
  • Unplug all USB devices except mouse and keyboard and then in Device Manager delete all your USB hubs.
  • Reboot. Let Windows find and install the USB hubs.
Install the drivers you downloaded from the Behringer website.
  • Plug in your Xenyx. Windows 7 will install the drivers and you should have a signal.
  • Make sure you select the unit is input and output default in control panel.
Mar 15, 2013 | Behringer XENYX X1204USB 12-Channel Mixer
Separate inputs on xenyx x2442usb using logic pro 9
Unfortunately, the Behringer Xenyx x2442usb only comes with a stereo USB interface. The documentation is a bit misleading, but you can only record two channels through the USB interface - the main mix L and R. If you need to record more inputs than that, you'll have to do them separately.
Mar 03, 2013 | Behringer XENYX X2442 USB Mixer
Unit behringer xenyx 1204 fx does not work
i'm trying to find the circuit diagram for a xenyx 1204 mixer
Nov 08, 2008 | Behringer EUROPOWER EP2500 Amplifier
Connection
There are 2 ways to have an EQ in the system. If the mixer (1204) has inserts for the mains, you can use a set of insert cables to connect the EQ. If not, connect the Output of the mixer to the Input of the EQ and the Output of the EQ to the Input of the Amp.
The insert cables will allow you to electrically connect the EQ as described above only using a single set of cables. These cables are 1/4" balanced or stereo at one end (Tip-Ring-Sleeve) and dual XLR at the other. You will need 2 insert cables, one for right and one for left.
Hope this helps,
dan
Jun 19, 2008 | Audio Players & Recorders
Behringer XENYX X1204USB/1204 USB 12-Channel Mixer Logo
526 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
