Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 won't turn on
One day everything was fine, the next day I couldn't get it to do anything!  The digital clock would not turn on and the brew function would not work.  Any thoughts?  Is there a "re-set" button somewhere?  I think I am still within the 3 year warranty, but I don't think I have the receipt anymore.
Thanks for any help you can give me.  Need coffee...
Kathleen
  • livvy6 Jan 04, 2009
    Exact same thing happened to me...I called Cuisinart and they said to re-set by disconnecting for an hour.  It worked!!
  • 8,596 Answers
Yep. Unplug for 20 minutes or longer officially. If it doesn't work, your serial number may still put you in warranty. They have a longer warranty period than anyone.
Posted on Jan 09, 2009
4 Suggested Answers
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
reyjoshua07
  • 1157 Answers
SOURCE: My Cuisinart DCC-1200 coffee maker
Hi mwhitwell,
You can determine where the problem is by using a multimeter. You may also check the bottom plate. Sit the pot while machine is turn on for couple of minutes, then try to see if it has heated at all. If no result, then the thermal fuse or the element has failed. The part is welded to one end of the heating element and cannot safely replaced by itself. Also, the thermal switch that causes the cycling of the element is clamped to the element and also welded to its connection points. The entire assembly will need to be replace.
Hope it helps.
Thank you for using FixYa.
Posted on May 16, 2011
  • 85 Answers
SOURCE: Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
Posted on Jul 08, 2009
Cuisinart Coffee Maker won't turn on
Does it indicate any Fault Error Code?
Does it have a clock battery to keep the clock working when power is off. Reset the clock,
Is the internal electronics sensing a fault or missing switch closure. Eg. Doors closed switches
Mar 02, 2015 | Cuisinart DCC-1200 Coffee Maker
How do I test on/off switch on Cuisinart DCC-1200?
Use a multimeter with a continuity buzzer,put it across the contact points,when it is on the buzzer abound and when off no buzz should be heard,also a test light can be used.
Jul 20, 2014 | Cuisinart DCC-1200 Coffee Maker
Set clock
Turn dial to "Clock"
Press HR button and MIN buttons to change time
Here is a link to the full user's manual - surprisingly, the directions are not in it:
http://www.cuisinart.com/share/man/25_man.pdf
-Tha Mp3 doctor
Mar 08, 2009 | Cuisinart DCC-1200 Coffee Maker
Clock not working
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Jan 10, 2009 | Cuisinart DCC-2000
I have a Cuisinart DCC-1200 coffee maker. It's worked flawlessly, but we just moved and when we arrived at our new house, we plugged it in and ....NOTHING! It acts like there is no power to the machine....
Most likely totally dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Dec 11, 2008 | Cuisinart DCC-1200 Coffee Maker
Dcc-1200 not working
Probably dead, but:
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
Jul 26, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
2,475 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
