Question about Miele S7280 Bagged Upright Vacuum
I am looking for a parts diagram for a Miele Upright S7280 (Salsa) vacuum
Would like a parts diagram so I can reassemble my vacuum after taking it apart to clean it (cat peed all over it and it smells to high heaven).
  • 33 Answers
See if there is a manufactures web site and inquire if diagram is available or just Google for info with proper make and model.
Fist just search for vacuum diagrams then refine search for your vacuum but this not always easy can be confusing so might have to take it to vacuum repair business or if you have not dissembled it yet just make notes when you do. Its not as hard as it seems I have done it many times.
Posted on Oct 24, 2012
futureloginn
  • 734 Answers
SOURCE: Miele Solarus Canister Vacuum stopped working
Miele S251i Plus Bagged Canister VacuumMiele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Posted on Dec 02, 2008
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
ukvacfan
  • 328 Answers
SOURCE: Miele Mistral S7280 won't run after changing the bag
The Mistral range is the same as the new S7 that's just hit Europe. Have you made sure that when you turn on the vac on the handle that you've switched the carpet mode on? There's a separate button just under the power on button that activates the Carpet setting. Other than that check the sole plate where the roller brush to check for a blockage.
Posted on Jan 23, 2009
  • 132 Answers
SOURCE: Miele Flamenco s 248i looking for help / diagram in fixing re win
it is easy !
1- unpluge from electricity
2- just a few screws with hexstar head (unscrew)
3-you will find the reel which catch this cord
4- try to rotate it by your self many times may that fix
5- if every thing be ok go in revers these steps
6- if not order for new one and it will be easy also just we will need amor step to disconnect a 3 terminals beside this reel
many thanks
Posted on Jun 23, 2009
  • 120 Answers
SOURCE: miele cat & dog vacuum will not switch on
Its probably the power cord itself or the reel that draws it back into the machine.
Posted on Jun 29, 2009
Why does it have little to no suction power on carpet?
either your hose is stopped up or your motor is going bad and doesn't have enough power, first clean out your vacuum and check belts and make sure they aren't worn out and broken or stretched
Dec 13, 2015 | Miele S7280 Bagged Upright Vacuum
The hose is blocked, how do I get it off to unblock?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the hose to start unblocking it, do the following:
1. Put the vacuum in the upright position
2. Press the release button of the telescopic wand and remove the handle from the hose
3. Push the hose elbow downward into the catch hooks.
4. Undo the suction hose by twisting it at the elbow.
If the blockage isn't in this location you can do the following to search further for blockages:
5. Open the service flap on the back of the vacuum.
6. Unscrew the screws and pull the cover free.
Below I have attached a link to the users manual for the Miele S7210. You should refer to page 30 to view the diagrams pertaining to my suggestions.
http://www.sylvane.com/media/documents/products/miele-s7210-twist-upright-vacuum-users-manual.pdf
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Oct 14, 2015 | Miele S7210 Bagged Upright Vacuum
Where is the belt in my Miele upright
You will need a Torx wrench (a special star-shaped wrench that is similar to an Allen wrench), to pull off the bottom plate. Once you do, the belt is easy to get to. Torx wrenches are a little uncommon, but they are normally sold in numbered sets, so either take the vacuum with you to the hardware store, or get a good idea of the size by looking at the screw head.
Jul 19, 2014 | Miele Vacuums
Milie won,t stay upright
If your miele is laying all the way down like mine is and will not stand upright..look for a dark gray corrugated plastic part where the handle bends at the base. This is above the silver holed plastic filter holder. This may be stuck. I just pulled mine out and then I was able to stand it upright again. I wasn't able to put it back in but I think it is there just to cover up the inside workings of the vacuum. So I left it out.
May 23, 2014 | Miele S7210 Bagged Upright Vacuum
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
What kind of upright or steam Vac should I buy which can make my carpet clean and SOFT?
I recommend looking at the miele S7280 for an upright vacuum cleaner and the royal RY7910 carpet extractor.
Jan 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Jan 20, 2009 | Miele ART S920 Bagged Upright Vacuum
Miele S7280 Bagged Upright Vacuum Logo
997 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
