Question about Toshiba CF36G40 36" TV
Toshiba CF36G40 36" TV (picture snowy)
When i hook my cable into the back of the tv i get no picture or sound. When i hook my cable up to a different TV it shows mithout a problem. I have tryed many different approaches to narrow down the problem including hooking my ps2 up directly to the TV. When i did this i recieved both picture and sound can someone please help as soon as possible, im stuck watching the NBA playoffs on a 13" screen. THANKS
  • Anonymous Mar 25, 2014
    we just hooked up the cable to the tv and it has a blue static screen and sound we just can't get the picture to come on
    Scholar:
  • 77 Answers
You have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try partsore.com. The tuner is the metal can the cable goes into inside the tv.
Posted on May 12, 2007
SOURCE:
Tv doesn't connect though coaxial hook up
Most of these TVs show a blank screen unless they are receiving a sinal?
Jan 28, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
Hooking VCR to DISH Network Reciever Box
In order to diagnose the problem I need your help.
Have you hooked the dish receiver directly into a tv or another device and had it working?
Have you tried a different cable at all?
Have you tried pressing the ant. button on the remote or tv/vcr button?
Please update me with as much info as possible and I will figure out where the problem is coming from. thanks
May 04, 2008 | Toshiba W627 VCR
1999 36" SONY FD TRINITRON VEGA #
It sounds that the tuner to your TV is faulty. It should be replaced. Before confirming, check the antenna connection for firmness, and the antenna wire have no breaks inside it. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Apr 23, 2013 | Televison & Video
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
The DVD player is running a movie with no picture or sound, the TV screen is showing an icon that says no signal...How do I get the movie to run with sound?
try using a different input on your tv. If possible try using a different cord to hook the dvd player to the TV. If neither solution works it sounds like a faulty dvd player.
also try using a different source on the tv like another dvd player, cable etc. etc. hopefully on the same input to make sure the tv is working properly .
Mar 03, 2011 | Dynex Televison & Video
Have no sound from VCR, cable hooked up properly, picture is great. TV is brand new.
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
Aug 12, 2010 | Toshiba M755 VCR
My TV doesn't have any sound with its cable. The
Tries difference setting in the SOUND setting,see how it turn out.Like setting in Variable setting,instead of fix setting.Setting in MONO setting,istead of STEREO setting.
Jun 25, 2010 | RCA 32F531T 32" TV
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Video 4 not working properly
9 out of 10 times, the problem is the device that is hooked up to the TV, and not the TV itself. This is especially true in the case of cable boxes, which have a long history of failures.
Temporarily, you can probably hook up the composite (yellow red and white) cables to get a picture and sound on a different input.
You can try to hook up a DVD player on the inputs (component, I'm guessing) and it will probably work. Then you get to call the cable company!
Hope this helps...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Televison & Video Logo
235 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
