Is it possible to bypass the heater control vale on a 1990 BMW 325i, as in running more direct heater hoses?
I believe this is what is causing my heater not to work on my BMW, as the car runs at normal temperature, gets good circulation but does not get heat inside the car but a very VERY minimal amount. I am new to this type of control vale having dealt with domestic cars, and by what I am understanding this particular valve can divert the fluid away from the heater core if stuck in a position because of the 3 lines running to it. Would love to just by pass this valve and run it more direct...is this possible?
  • terry kimble Oct 24, 2012
    meant to say valve in a couple places..it's 5am, please excuse my typos
frcs68
  • 1605 Answers
SOURCE: TOYOTA CAMRY 2001, WHEN SHOULD THE FANS SPIN?
when the car is running, there is enough air to cool the radiator, however, when when the AC kick on, the radiator absorb more of the heat from the AC coil. there by require more cooling. the 2 fan are there for that purpose.
as far as the smell of antifreeze, you nee to check all of the cooling hoses, in the engine compartment and under the dash. sound like there is a small leak some place.
Posted on Nov 12, 2008
gordanddar
  • 477 Answers
SOURCE: temp guage showing hot, not getting any heat for 1992 Mercury Cap
If the hoses to and from the heater core are hot , and you say the heater core is hot , then the only answer is that the air duct that flows into or out of the heater core plenum ( housing ) is not opening.
Heater control on dash borad inoperative.
Not sure about 92 capri , some cars have a cable linkage , some work on vacume motors.
Try to find a haynes manual for your car , they will walk you through almost every step of anything you may ever want to do to your car.
You seem to know what you are doing , but I gotta ask ........the heater core you felt was up behind the dash inside the passenger compartment of the car right ?
Posted on May 10, 2009
  • 507 Answers
SOURCE: I have a 2002 passat with no heat I put a garden
check the heater tap,it controls the flow through the heater core,it sounds like its not opening.even google images to see what it is and where its located,its a fairly straight foward fix,depending on why the tap wont open
Posted on Oct 21, 2009
gordanddar
  • 477 Answers
SOURCE: 1995 Chrysler Cirrus overheating
Probably not water pump. Engine is notourious for vapour lock.
Cooling system must be blead of air before thermostat will work. Cool bottom rad hose is a dead give away. If you are still watching this forum reply , and I will walk you through the only way I know how to make it work properly. It's actually easy if you do it my way. I have worked on lots of cars , and this engine was the hardest to bleed out. Did one Yesterday , and works perfect.
Posted on May 16, 2010
Testimonial: "I need help on how to bleed the system thanks"
  • 118 Answers
SOURCE: NOT GETTING ANY HEAT AT ALL, REPLACED WATER PUMP,
Make sure the blower runs, then make sure the heat and ventilation control doors move as they should. If you have hot coolant flowing through the heater core, air flow through the core, and appropriate air flow path, then you will have heat.
Posted on Aug 12, 2010
1989 bmw 325i heater core removal im at the heater core already. need to know how to get it out
Some heater cores come in a plastic case. If yours does, you have to remove it as a set. Disconnect hoses from inside the engine compartment and remove all hardware that holds it in place. Once free to remove, careful not to spill antifreeze inside your car.
Nov 16, 2016 | BMW Cars & Trucks
My 2006 BMW 325i automatic transmission is stuck in 3rd gear
I believe that is 'limp mode'. You want to get a vagcom reader to see what codes it is posting to see what the cause is.
Oct 16, 2016 | 2006 BMW 325i
1994 bmw 325i auto at idle rpm go up and down
A lot of older automatic BMW's do this, If you restrict the idle air valve with a hose clamp it will stop. As for making the "repair" I have tested and tried all things related with that bypass and over the last 4 years have yet to find out why.
Sep 16, 2011 | 1994 BMW 3 Series
I have a 2006 bmw 325i 3.0L E90. Car has been overheating and got a code of P0597 Thermostat Heater control circuit open. I replaced the thermostat with a new aluminum Wahler unit. Just drovve it for 10...
IT sounds like heater control valve not thermostat. Check Pelican Parts.com or BavAuto.com for tech advise & tips. Also check RealOem.com (enter your cars specs and you will see exploded diagrams)
Apr 04, 2011 | BMW 325 Cars & Trucks
I need to know the location of bmw 325i 2002 were heater not work
Its usually directly on the speed selector know or mounted to the heater plenum behind the glove box (this is the prinicple for american cars sonot sure if foreign makers follow the same principle) its about 2"x2". Very small and looks like a microchip with a circuit and wiring in it...
Nov 05, 2009 | 2003 BMW 325
My bmw 325i as heating problem,we replace the water pump,termostate,and radiator,but its still running hot ,any suggestion
my 1990 325i bmw is running hot
it seems to have a lot of air in the cooling system
i replaced the head gasket, water pump and thermostat
how do i get the air out of the system
Sep 16, 2009 | 2001 BMW 325
1997 bmw 316i compact, thermostat??
it may be possible that your heater core was faulty and some has by passed it. open hood and check for incoming and outgoing heater hoses into firewall(dash of car). it is also possible that the heater core is plugged, try getting your cooling system flushed
Sep 09, 2009 | 2009 BMW 3 Series
Hot air on passenger side and cold air on driver side on 2004 BMW 325i. Why?
if you have the separate climate controls the unit might have shorted out and caused the heater coil to be constantly engaged
Jul 08, 2009 | 2003 BMW 325
Idles too fast. Back pressure in case. How do I fix this?
Clean out the blockage in the engine gas recirculation and or idle by pass.Sounds like a blockage or the idle bypass has failed
Feb 15, 2009 | 2001 BMW 325
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
