Question about Poulan Garden
P3314 no spark - Poulan Garden
  • Poulan Master
  • 7,482 Answers
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark,be sure that you ground it good.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position in relationship with the flywheel
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Please take time to rate me
Bud
Posted on Oct 25, 2012
Testimonial: "very helpfull"
  • 1 more comment
  • ray8292
    ray8292 Oct 27, 2012
    Thanks for your help ,I have a ignition module on order i will let you know if this fixes the problem
  • Curtis Sewell
    Curtis Sewell Oct 27, 2012
    I am pretty sure your problem will be solved with the new module...
  • Curtis Sewell
    Thank You ray8292...
HOW TO ADJUST THE CARB. ON A MODEL P3314 WILL START AND RUN FOR ABOUT 15 SECONDS AND THEN STOP RUNNING.
suspect that the diaphragm is going hard and is not sucking the fuel up from the tank properly
rekit the carby
Oct 02, 2016 | Poulan Garden
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
My 33cc /14" model p3314 chainsaw used to run ,
1. get a new spark plug
2. make sure the shutoff switch is working (clicks into the correct position)
3. If these do not work and you are a mechanic, get a manual and follow testing.
4. If you are not, find a reputable repair shop
Oct 06, 2014 | Tools & Hardware - Others
New spark plug plus new air and fuel filter. Chainsaw will not start or even fire.
If there is a good spark and fuel getting to the plug there are only two reasons why it will not fire, sheared flywheel key knocking the timing out, or it has partly seized and has low compression.
Aug 09, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Saw has spark,compression,and fuel will not start
if u but fuel 5 ml in to cilinder and not starting then is problem in spark. if it starts and stop agein then is problem in garburator.
Mar 03, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Oct 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Saw does not idle and is hard to start. It is a P3314 Poulan
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Jun 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Will not start
Hi, do you pump the primer til is's full before starting?
Mar 18, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Garden Logo
213 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
