Question about Kyocera Ecosys Fs-1128mfp 30ppm All-in-one Laser Printer - Fs-1128mfp
Remove original from document processor - Kyocera Ecosys Fs-1128mfp 30ppm All-in-one Laser Printer - Fs-1128mfp
3 Suggested Answers
  • 8 Answers
SOURCE: The screen say "remove original
There is a 3 inch long plastic arm under the top door of the top feeder. This is a sensor arm. It is most likely broken. See your local copystar dealer for a replacement part.
Posted on Aug 05, 2010
  • 29 Answers
SOURCE: "remove original from document processor"
Sensor in feeder is probably broken. To get around this until you can get it fixed power down the unit and unplug it. Unplug the cable that connects the Doc feeder (in the back) to the main unit (two screws hold it on. Then power the unit back up it will work with out the Doc feeder. You will just have to put the copies on the main glass.
Posted on Jul 14, 2011
Kyocera fs -1030d printer show message removal original from document processor
These are notarius for having a cabling problem.the cable that runs from the d/f to the main unit go bad. It's a process to change one I would seek help by a person that has done it. Could be the flag or accuator that the paper hits. Or just a sep roller can do a lot for a sick feeder.
Feb 11, 2017 | Kyocera Mita FS-1030D Laser Printer
Printer reads remove original from document processor but there is no jam.
dear
any of the document sensor defective or its lever latched.
The sensor may be replaced or re aligned levers may overcome the problem.
Thanks.
Feb 11, 2015 | Office Equipment & Supplies
How to reset kyocera km 6030 Double sided copy mode. When i want to copy double sided page then i will see in screen... ""Reset All Originals in Document Processor ""
I think the message is "Reseat All Originals in Document Processor". This message apears when there was a misfeed or something like that. It means that you must put back all the documents, to be scanned again. Clean the paper feed/pickup rollers with a cloth dampned in alcohol.
Jan 21, 2015 | Kyocera Office Equipment & Supplies
FS1128MFP Printer. Sensor arm popped out and tells me to remove originals from processor. Arm is not broken and fully intact but I cannot find out where it belongs or how to put it back in.
You must reseat the black sensor flag on the document processor cover. Open the cover and you will see the right position. The flag gets into the optic sensor from the back.
Jan 06, 2015 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
The printer displays "remove the
It sounds as if you may have something holding on one of the paper detect sensors.Try manualy pushing (carefully) a thick piece of paper through the feed path to clear any blockages.
Sep 20, 2011 | Kyocera FS-1118MFP Laser Printer
Jun 29, 2011 | Kyocera Copystar CS-1820 Black and White...
The screen say "remove original document from processor" and there is definitely not a document stuck in the machine!
Aug 04, 2010 | Kyocera Copystar CS-1820 Black and White...
Can you help with kyocera cs-1820
Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
Feb 11, 2009 | Kyocera Copystar CS-1820 Black and White...
Remove original document from document processor
okay i imagine you have software
control panel add/remove
uninstall any old printers/scanners/copiers
also uninstall the printer you just added
restart your system make sure new printer plugs are in correct
then reinstall your software before trying to use restart system
please let me know what happens
what version of windows do you have
Feb 11, 2009 | HP Computers & Internet
Deleted document
No you can't the original file has now been replaced.
It's no different from deleting the file in the first place than creating a new document with the same name.
Aug 17, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Kyocera Ecosys Fs-1128mfp 30ppm All-in-one Laser Printer - Fs-1128mfp Logo
657 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
