Question about AM Auto Parts 1997 to 1999 Ford E350 Van Air Flow Meter with Housing for V10 6.8L
What do i fix for a code p1400 on a 99 ford e350 van
Battery lite comes on when driving above 2300 rpm's
It is likely that your alternator or voltage regulator is faulty. Take it to an auto electrician who will be able to fix it for you.
Jun 09, 2016 | aFe 2004 Ford Ranger - 4.0L V6 - Air...
Does check engine light reset after replacing faulty gas cap.
A check engine light will not clear itself! The light will have to be code read and reset using a OBD code reader.
Feb 26, 2015 | AEM Brute Force Intake 2003-2005 Ford...
What is the SPINDLE in the front brake system?
In the average brake system this refers to the tapered stub on the front suspension knuckle, which mounts the front hub and bearing assembly. It has a thread on the end for the front hub nut (not wheel nuts).
The actual appearance varies widely from car to car.
http://www.ss396.com/mm5/graphics/00000001/FM-3712.jpg
Nov 12, 2014 | AM Auto Parts 1997 to 1999 Ford E150 Van...
How do you fix a code P 1506 ?
Hi Joel,
Here's what you were looking for. Idle Air control valve
http://upkeep.us/OBDII/OBD2/Ford/piart.php?art=5282
2.3L 2002 Ranger part page for reference & repair video. Same engine, etc...I do not work for Rockauto it's just a part/price reference.
http://www.rockauto.com/catalog/x,carcode,1372676,parttype,6072
Repair video
https://www.youtube.com/watch?v=iQr6E9Z7sg4
FYI, video for IMRC shows issues which are sometimes related.
https://www.youtube.com/watch?v=qLqpQeIJXek
PEACE
May 09, 2014 | aFe 2001 Ford Ranger - 2.3L 4-cyl. engine...
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
Code po351
Its not the plugs. It is either the ignition coils or the crank sensor
May 06, 2013 | Spectre 2006 Ford Econoline - E250, 4.6L...
Van does not stay running.
Yes, you have a fuel pump in the gas tank.
But, before you replace the pump, check the fuel pressure.
Mar 26, 2013 | AM Auto Parts 1997 to 1999 Ford E350 Van...
AM Auto Parts 1997 to 1999 Ford E350 Van Air Flow Meter with Housing for V10 6.8L Logo
96 people viewed this question
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
ray gallant
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
