Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garrage door opener won't open all the way and sometimes it won't close also
  • 1 more comment
  • tamaserr Jan 03, 2009
    What do you mean by operator? If you mean remote control panel and wall mounted hard wired panel, the answer is yes. And yes, if I disconnect the trolley, it works manually. I can open the door thru the wall mounted panel one push at a time, until the door is fully opened. Otherwise, it will only open partially, for each push of the button. My garrage door opener is a Chamberlain Liftmaster Professional 1/2 HP with part No. 41A5389-1D.
    Thanks for your concern.
  • tamaserr Jan 05, 2009
    Dear Guru,
    Your solution is perfect. I turned the 2 screws clockwise: from 6 o'clock position to 7 o'clock, Left hand screw ; while the other one from 5 o'clock to 6 o'clock position, Right hand screw. I appreciate it very much.
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    What kind of operator do you have? Does your door run ok manually
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If the door runs fine then check the up force and down force on your operator (the box that hangs from the ceiling). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up/down arrow to a higher number.
Posted on Jan 03, 2009
I have Craftsman 1/2 hp Door Opener(2005) screw drive. When opening the door pully connected to the screw drive gets to about 18 inches from operator and stops leaving the door only 3/4 open. I have adjusted both the up and down screws on the operator to no avail. Interesting though, about 1 in 10 attempted openings, the door opens all the way.
Help!
Posted on Feb 24, 2009
3 Suggested Answers
  • 3197 Answers
SOURCE: My garrage door is closed. The remote is not
If you have no way to enter the garage but through the large door you will need to call a technician. They will drill a hole through the door and then use a tool to reach the manual release. They can also install a keyed manual release so you don't have this problem again.
Posted on Dec 21, 2009
swolfinor
  • 504 Answers
SOURCE: garrage door opener ability to close the garrage door
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Posted on May 30, 2010
What do I need to do in order to get the back door on the passenger side to close? A tech from AAA said I needed a spring for the door latch?
if it won`t close look at the door latch mechanism. there should be two u shaped claws that close around the door striker plate pin, sometimes these get closed before the door is closed causing the door not to close and stay closed. if they are closed(claws) pull the door handle to open the door and take something and push the claws out(open) then close the door.
Jul 08, 2014 | 2000 Plymouth Neon
My phone is download to slow too much page open i would like close them
There is an internal circuit error when you turn up the garrage the current flows through the circuit but during the other half during the closure of garrage the current stops due to over flow you have to change the circuit board of the remote
Apr 25, 2014 | Cell Phones
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Our garrage door won't close. There is nothing in the path. It was working smoothly until 1/2 hour ago, and now it won't close. Please help !!!
If the main light flashes 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each of them is lit and not flickering ever so slightly. If you cannot get both lights to come on you have either bad wiring or a bad sensors.
If the main light doesnt flash 10 times you probably have a bad RPM sensor which is a small printed circuit board just in front of the motor.
Be sure to try increasing the down force also. The control is on the rear of your motor unit near where all those white wires go.
Feb 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garrage door is closed. The remote is not working. The switch is in side the garrage. How to open
Dec 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wont open when I press door opener. makes a clicking sound and reset light is blinking
I, PRESS THE REMOTE THEN UNIT START TO BLINK THE LIGHT. ALSO IT WORK WHEN HOLD THE MANUAL SWITCH TO CLOSE AND OPEN THE GARRAGE DOOR.
Oct 27, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
I am trying to program my garrage door openner to my car but it is not working, any advice please?
WHAT KIND OF CAR YOU HAVE AND WHAT KIND OF OPENER ,REAR OF THE MOTOR EXIST A LEARN BUTTON WHAT COLOR HAS AND WHAT COLOR ANTENNA IS.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garrage door opener not operating after thunder storm
If you had an lightning storm you most likely have a bad logic board. That is not a reset button you are pressing.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garrage door opener ability to close the garrage door
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,705 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
