Question about Samsung Np-qx411-w02ub Core I5-2450m 2.5ghz 6gb 1tb Hdd 14" Wifi Dvdrw
How could i setup a new windows when boot manager not work properly
Setup a new windows but boot manager is not work properly
    Scholar:
  • 106 Answers
You can boot and setup windows using either of the following ways:
a) If you have a boot able CD/DVD of Windows, then go to your BIOS setup and set CD/DVD as your First Boot Device and then save setting and exit. Place the CD/DVD of windows in your CD/DVD Rom and setup shall start.
b) If you don't have a boot able CD and have a backup on your hard disk or any place else, then you can create a Boot able USB easily. Follow the link below for getting a free utility and how to create a disk like it.
http://www.megaleecher.net/Make_Bootable_USB
Posted on Oct 24, 2012
Testimonial: "Thanks. Your solution is helpful for me."
H-L DATA STORAGE DVD WRITABLE/CD-RW DRIVE MODEL# GSA-T10N
The great thing about Optical Drives is their standardization, and you normally don't require a driver for initial setup. It is not seeing the drive or the disc is not bootable. Or, both.
You need to make sure it has power. Then check BIOS by pressing an F key noted during boot (F2). The drive must be listed or this is your point of failure. You may have to physically reseat the drive. Next make the CD\DVD first boot and try again. Check disc on a different PC to insure it is bootable.
---------------------------------------------------------------------------------------------Setup from Windows -
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Nov 10, 2012 | Acer Aspire 5050-3371 Notebook
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
My Samsung i5 laptop does not want to boot.It first got stuck at starting Windows so I did a complete restore and now it says that the boot manager is missing.
Hello.
It's possible that your Master Boot Record is corrupted. To fix:
1. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
2. Once the setup loads, you will see the option to press R to repair a Windows installation.
3. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password (no password, just hit Enter, unless you changed the password).
4. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
Hope this helps.
Jan 27, 2011 | Samsung Computers & Internet
Toshiba Satelite Pro L300 won't boot up properly.
firsly start your computer in safe mode then do syatem restore .if problem will not solve then mail me at vicky.akon11@gmail.com
Jun 26, 2010 | Toshiba Satellite Pro L300 Notebook
New battery calibration, drain battery, windows will not boot
sounds like OS was not fully installed properly----Reinstall.
May 15, 2010 | ASUS Eee PC 1000H Laptop
Xp pro set up
copy ntldr file from i386 folder and paste in C:\
steps
  1. Use the Windows Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears:
Feb 22, 2009 | Microsoft Windows 98 for PC
My PC will not start properly - when I turn the computer on, I get the Windows XP start-up screen, and then the screen just goes black. I can see the cursor, but when I move the mouse nothing happens. I...
you may try
1) if you reinstall windows xp but it can't boot from xp disk, you may set the cdrom to piority at bios setup screen, still no boot, you need check your cdrom works status
2) if you reinstall windows xp but display no any hard disk appear that means the HD damaged, you need replace a new HD then do again
3) update some devices driver maybe needed, check from control panel--system--device manager, any triangle yellow mark, you can search from website acording the device model name, download and update them.
Feb 08, 2009 | Computers & Internet
A recent mac laptop with Tiger & bootcamp/win XP will connect to the internet via a Netgear DG834G adsl modem with ethernet cable in tiger & XP but only in xp with wireless. Any advice? JL
If I understand you correctly you have an Intel based MAC, with the boot-camp boot manager, so you can choose to boot either from the native MAC OS or from Windows XP.
The system works fine from the MAC OS, but the (wired) ethernet does not work from XP.
1) When you boot into XP mode, the XP operating system is in
charge and the MAC OS is dormant.
2) Check the XP device manager to see if the ethernet NIC
(network device) is properly installed and if the device
drivers are functioning.
From Windows XP:
Right click My Computer ==> Properties => Hardware ==>
==> Device Manager ==> Network Adapters =>
==> Your network controller
Right click on your network controller ==> properties
Check the device status !!!
2) If the device is NOT working properly, you may need to
download and install a device driver for this card.
3) If the device IS working properly, you may need to run
the NETWORK SETUP WIZARD from the control panel:
START ==> Control Panel ==> Network Setup Wizard ==>
==> Next.
4) Assuming you are connecting to DSL with a login password,
use the: "My computer connect to the internet through a
modem" option.
If your DSL is always on, or if you use a local router to
connect to the DSL modem (the router does the work)
Then you choose the: "My computer connects to the
internet through another computer or a residential gateway"
option.
Martin
Apr 22, 2008 | Computers & Internet
Microsoft Windows 98 for PC Problem is there any software driver for pen drive so that my win98 o.s. computer can detect any type or companies pen drive plz tell me
wow, the 90's are a calling... sure their is a roumor of a usb pen driver for win 98' ....
Windows 98, especially in it's second edition (also known as Windows 98SE), handles USB fairly well, however there are no generic/universal mass storage device drivers preinstalled in the operating system, so you will need to install some additional drivers for it. Some manufacturers do however, provide the Windows 98 drivers on CD, others have them available to download, and others simply do not have them available at all!!!!!!!
generic Windows 98SE USB mass storage device drivers:
http://www.technical-assistance.co.uk/drivers/nusb31e.exe
instructions?? :
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager (*carefull)
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
as always good luck! now im going to go back to my windows 95 and play Bioshock on full graphics!! excuse me = )
Oct 13, 2007 | Microsoft Windows 98 for PC
Samsung Np-qx411-w02ub Core I5-2450m 2.5ghz 6gb 1tb Hdd 14" Wifi Dvdrw Logo
254 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
