Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Washer part wont move just makes buzz like sound. however it will fill water,and drain. just wont move. please someone help me i am a woman and dont know where to begin with this. i can get someone to put broken part in for me just need to know whats broke and what part to buy.
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
my whirlpool thin twin washer wont agitate it just - 1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
Posted on Feb 15, 2013
  • 2468 Answers
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
Posted on May 10, 2010
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
  • 1314 Answers
SOURCE: will fill water but agitator wont run.
you have a broken motor coupling if you want to tackle this your self then reply to this message and i will tell you how if you have to rate me to reply then give me 4boxes im not sure how this site works you can do it if you like to tinker
Posted on Jan 01, 2008
  • 7 Answers
SOURCE: whirlpool thin twin filled with water then stopped!
Not sure about the dryer but there are a couple things that could cause the no draining issue.
You could have a leak or block in your pressure hose. Basically there is a thin, clear tube inside the cabin that attaches to the tub on the lower right side. If this has a leak or is clogged then the washer has problems filling and draining.
The other possible problem is a broken lid switch. This is an easy fix. Basically, the mechanical mechanism that goes down when you close the lid does not work properly so when it comes time to drain, the washer actually thinks the lid is open.
For both of these you would need to open cabin. I posted instructions for that here:
http://www.fixya.com/support/t1885690-whirpool_twin_washer_dryer_lte5243dq3
Posted on Apr 03, 2009
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Thin Twin will not spin!
best left to a qualified service person
Jan 25, 2014 | Washing Machines
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
My thin twin wont drain. Checked drain pump and it was clear. When i got all the water out it would spin. It will fill, agitate and spin(as long as there is no water)
The basket drive and or clutch need replacing, as long as their isn't the added weight of the water it spins yet add 250 pounds of water weight its slipping
Aug 03, 2011 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
260 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
