Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
My front loader does not get no water in it
When i turn on my front loader it doed not fill with water
  • Official Brand Answer
  • 4,342 Answers
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
Posted on Oct 26, 2012
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
Front Loader Humming
Thats normal just the water valve
Dec 15, 2009 | Samsung WF328AA Front Load Washer
My duet front loader will fill with a large
there are two water valves above the soap drawer, that are sping loaded to stay shut when power is off. if the water pressure to the machine has increased, sat due to an increase in main pressure from the water board fixing a leek further up the supply, then this could force open the valves. try turning the stop valves at the inlet pipe end, away from the machine, down a quarter turn and see if this stops it.
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
LG front loader - shower water filling up machine
your drain should have a backflow device in it. This can be very dangerous, you need a professional plumber ASAP.
Feb 17, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
203 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
