Question about Acer Aspire 3620 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter
My acer 3620 keeps freezing up
Keeps freezing up
    Novelist:
    Champion:
  • 233 Answers
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Acer Aspire 3620 AC Adapter
Posted on Oct 25, 2012
  • Acer Master
  • 27,725 Answers
Laptop hang issues can be a frustrating issue for the user and a tedious problem for a technician.
The variety of causes for this event are staggering, but many can be diagnosed in a few simple steps.
Peripheral Issues
USB drives, inserted before boot, will cause a hang.
Remove all such devices and media (such as CDs and floppy disks) before booting your laptop.
Software Causes
Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help
you check for software causes for a hanging laptop.
By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance.
Perform a check disk by right-clicking on your "C Drive" found in "My Computer."
At the "Properties" link, press the "Tools" tab to schedule error checking.
Reboot your laptop and let it perform this check.
Hardware Causes
Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it.
Do not touch its gold contact points, as this may damage the memory.
Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk.
If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU.
Boot with the battery removed to verify that there is not an issue with power conflicts.
Final Considerations
Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes.
Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data.
This process requires your original Windows disks but is often quite useful.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
Posted on Oct 24, 2012
Freezing
A computer/notebook/laptop can freeze due to a lot of reasons. Here are few noteworthy ones. Check them and see if they help, if not then post a little detail of when it freezes more etc:
a) Antivirus programs have a great tendency of eating up memory quite quickly. So, get a lightweight antivirus program like Microsoft Security Essentials or Avast etc.
b) If you have a low RAM then it is recommended that you run very few applications at the background. Avoid running any unnecessary applications.
c) If you have a desktop set with lots of transitions and effects it can cause huge RAM and often results in freezing of system.
d) Your O/S could be a problem too. If the above things doesn't help try resetting/re-installing the O/S and hopefully it shall help you a lot.
e) Check your system for any viral activities. You can perform an online scan using many free online scanners like Trend Micro etc.
Oct 24, 2012 | Acer Aspire 3620 Laptop/notebook
Acer aspire 3620 window problem..bios password forgot how to install new window
mmm for me the best solution is reinstall de windows, to recuperate the password is so hard.
Oct 11, 2010 | Acer Aspire 3680 Notebook
Laptop doesn't show up in acer listing
Probably the model number of your Acer Aspire 3620 is already discontinued or placed into their archive files. Also, possibility that such model was produced in limited quantity & distributed only to a certain location like in the Philippines. I suggest to email them for your concern thru service@acer.com.ph, for their customer service & support. best regards
May 17, 2009 | Acer Computers & Internet
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
Component missing Acer aspire 3620
Hey,
The vga board on this laptop heats up very easyly and the heatsink is uselessly small. Video may fail withing 12 months. I would recommend another laptop model, this series 3xxx and 15xx have cooling issues and parts fail often. Not much you can do about the problem.
Thanks,
Ekse
Aug 19, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3620
I hope this helps:
This first link is for windows vista, if thats what you are running
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-3620-Bluetooth-Driver-601.shtml
now the this one is for windows xp: click the link and then click the little green box on the left witht he arrows pointing down.
http://www.notebook-drivers.com/ViewDownloadUrl.asp?ID=87869&brNum=3&show=0
Jan 21, 2008 | Computers & Internet
Acer Aspire 3620 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
