Question about HP PSC 1315 All-In-One InkJet Printer
Flashing light check print cartridge
I have an hp psc 1315 all in one. The light flashes stating that I need to check my print cartridge. I have no indication that my ink is at a low level so I took out both the color and the black cartridge and reinserted them, no change. I've turned the machine off, no change. I've unplugged the machine and tried cancelling the job, no! Thanks, robin
  • 2 more comments
  • amyrong Jan 03, 2009
    omg, the same thing happened to me today.
  • atr22skier Jan 08, 2009
    I replaced both of the cartridges, and the light is still flashing...
  • tights_n_ups Jan 16, 2009
    I replaced the color cartridge first since I had replaced the black one in the last several months. Problem solved. Although the last printer I had showed ink levels on my computer. Thanks for all the feedback!
  • Anonymous Jan 16, 2009
    I replaced both of them, and they work. Try cleaning the inside of the printer thing. Go to HP and find out how you can clean it. Might help
I had the same problem. All solutions given by HP did not work. I took the printer itself to the refilling shops. They checked the circuit of both catridges and declared the black one cicuit is faulty. When they replaced this faulty catridge, the error disappeared. No need to change both cartridges. But we have to identify which one is faulty by using these cartridges in a similar printer.
Hope this is of use.
Posted on Jan 07, 2009
  • 2,120 Answers
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Wont print lights flashing even after new hp ink installed - what now?
I had this psc and usually the ink was leaking or the cartrige head needed cleaning, or the cartridge was not installed properly. Just check these 3 things and you will find the problem.
Apr 07, 2010 | HP PSC 1315 All-In-One InkJet Printer
When i switch on the printer the error light comes up it is flashing on check printer cartridge it wont let me print
Try to clean the contacts on the carriage unit with piece of cotton and little alcohol.If this not help replace the ink cartridges.
Oct 05, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer not printing
Replace cart. or clean the print head and absober you will need a printer cleaning kit for this task.
May 25, 2009 | HP PSC 1315 All-In-One InkJet Printer
Check print cartridge light flashing
Hi !!
It means that you need to refill your cartrige or replace it with new one. Hopefully it will solve your problem. If you still have any query let me know please.
Thanks Irfan view
May 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
"check print cartridge was flashing, so I changed the ink, but it still is flashing. Also, there is an "E" across from the copies button. I disconnected it from the computer and "check print cartridge...
hi, is it hp ink cartridges? did you refill cartridge or replace?
press cancel button, then on/resume. if no change. make sure all tape, paper is removed from ink cartidge connectors and there is no dirt, smudges or adhesive or anything else that may interfere with the connection. reinstall cartridges. if still no change, power off, then disconnect power. wait about 5 mins. reconnect and power on. this should reset the printer.
Apr 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
Troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Feb 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
554 people viewed this question
Ben Johnson
