Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool American Fridge Freezer
Having changed the filter in my whirlpool american fridge freezer no water coming out of water dispenser despite switching on and cleaning what ever could be possible, no blockage appears in the pipes ?
  • 37 Answers
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Posted on Jan 03, 2009
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
My whirpool 6th sense american fridge freezer has stoped making ice? The water is still live, th eonly problem appears to be the level control arm which is in the up position and want move?
Be very careful, when the ice maker malfunctions, many things can be the culprit. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Water dispenser not working on my whirlpool american fridge freezer ? Changed filter a week ago, is switched on but no water coming out of dispenser?
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad. If that is not it than there is a switch problem at the door.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Jul 16, 2008 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
462 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
