Question about Ovens
I have a defy Gemini double gourmet oven. It's about 4 years old. Just recently the bottom oven stopped working, that includes all the knobs and timer and relevent switches on the board. The only
All the switches on the board related to the bottom oven does not work at all. My old Defy Gemini had the fuses in front under the control panel which was easy to change. I see screws in the same position on my new oven but not sure if they contain fuses. Defy wants to charge me R 500.00 just for a call out. If it is a fuse problem, I would save a lot of money that I actually do not have at the moment
  • 254 Answers
SOURCE: Control panel of Defy Multi Function Oven not working
If the control panel has delaminated they are covering this under warranty from what I have seen.
Hope this helps Ya
Posted on Jul 05, 2008
  • 3361 Answers
SOURCE: Oven blows main switch
There is a short circuit between the lower oven control and the lower element.
Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
If it does not blow, replace the lower element with a new element.
If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
If you get continuity replace the damaged wire..
Finally, check the control knob switch for continuity to ground on the frame of the oven.
Posted on Mar 20, 2009
  • 4905 Answers
SOURCE: The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Posted on Sep 01, 2009
  • 1922 Answers
SOURCE: Are there fuses in an Eaton Viking wall oven
you have lost one leg of input power that gives you 240 volts check both legs for 120 volts each for a total of 240 volts
Posted on Oct 05, 2009
  • 353 Answers
SOURCE: Defy 424 oven not working
Probabley a faulty element
Posted on Nov 25, 2010
My defy gemini gourmet oven is too hot! when i bake, my cake his burnt pitch black on top and is raw on the inside... please help
I don't know about that particular over but when that is your result, it is usually because the oven is on Broil (Top burner is on, used for steaks, ribs, things like that) instead of bake (Bottom burner is on with a more distributed heat for baking since the rack isn't too close to the heating element)
Recheck your settings :)
Jan 10, 2018 | Ovens
My defy double door gourmet thermo oven overbakes cakes on the outside what should i do to ensure even baking
Reduce the temperature slightly or get an oven thermometer and follow the recipes.
Aug 01, 2017 | Ovens
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
Oct 10, 2016 | Ovens
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
Bottom oven does not work tim eflashes and gives 0-.-7
Child lock is activated go to last page.
Apr 12, 2014 | Ovens
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
Or google " Gemini Petite Chef manual " and the first hit has the link
Jul 08, 2011 | Ovens
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
