Question about Apple LED Cinema Display 27 inch flat panel
Apple Cinema Display 27 keeps black
My recently purchased Apple Cinema Display keeps black since today when I connect my MBP. It used to work until yesterday. The display is connected to power, it's power supply for my MBP is working and the USB-hub is also working. When I connect it to the mini dieplay port, OS X is detecting it in the screens options and is extending the desktop so I can ove my mouse cursor to the other area. It kept black once last weeks but unplugging it from power and plugging it back in worked. Now it does not. I have restarted my laptop and unplugged the display multiple times. Anything else I can check or do on my own before returning it to the dealer?
5 Suggested Answers
actionman14
  • 32 Answers
SOURCE: the USB/ Fire wire connections do not work with my Apple display
try updating the drivers sounds like a software issue conflicting when putting other connections in
actionman
Posted on Feb 27, 2009
  • 12 Answers
SOURCE: IPhone does not power off
soory man but because Apple is so strong with there (high tech) stuff ther no other way out. i would have it replaced. i have a G1 i recommend you to get it! its just like the iPhone just open source so it has lots more freedom then the iPhone. the thing is its only for T-Mobile. you can get one unlocked thogh. but just tell apple to replace it for you.
Posted on May 28, 2009
SOURCE: Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Posted on Jul 20, 2009
Moozler
  • 3 Answers
SOURCE: Apple Cinema Display 23"
Hi all,
I had the “short long short” blinking led problem with my
23′ ACD after a power outage which left my screen blank and
my cheek wet with a tear for my baby. I read somewhere that
a guy was getting a 1 volt reading on the middle pin of his
damaged 90 watt power block. I figured maybe the display might
work if I could somehow block the middle pin. So I cut a small
strip of paper wide enough to block just the middle pin and long
enough to cover both sides and it looked like a “W”. I gingerly
pressed it into the brick receptacle with a toothpick leaving
just a little slack so it would not tear when I pushed in the
small white plug. It was a bit of a tight fit but guess what.
IT WORKED… I am now enjoying my beloved monitor anew and saved
$$$ on replacement brick or repair.
If you want to try it and you feel you’ve nothing to lose, make
sure you cover just middle pin (both sides) and you may have to try a couple of times. It worked for me, I hope you have good luck too.
Regards, Moozler
Posted on Oct 27, 2009
MBP cannot start black scteen with boot up sound
Hi JJ Su,
To connect an external monitor to your MacBook Pro, you will need an adapter that connects to the mini-display port on the MBP, and has another plug that is appropriate for your external display {VGA or DVI}.
Take a look at Amazon to find a relatively inexpensive adapter if you don't already have one.
-Please make sure that you order the right kind of adapter for your MBP since there Apple has used 2 different kinds of ports depending on the particular model!
FYI, if the external monitor doesn't work either, then you probably have a bad GPU {Graphic Processor Unit} on the motherboard. IF the external does work, then you either have a bad internal screen, or some bad connectors/wires inside the MBP...
Hope this helps & good luck!
Apr 15, 2014 | Apple Computers & Internet
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
It stopped working
check the power supply board which failed. look for blown fuse and replace any bulged capacitor.
Sep 07, 2012 | Apple LED Cinema Display 27 inch flat...
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
MBP Graphic Chip Failing
Flickering screen, solid horizontal or diagonal lines of light, start up but no screen. Connect another display to the DVI port, if you get a signal, the display is toast, if not- the GPU is. APPLECARE?
Aug 12, 2008 | Apple MacBook Mac Notebook
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
Oct 17, 2007 | Apple Studio Display 17" LCD Monitor
Apple LED Cinema Display 27 inch flat panel Logo
64 people viewed this question
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Michial Gueffroy
Jax Planet
Jax Planet
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
