Question about MSI Ultra Ms-6837d Ms-1637 15.4" Notebook T5250 1.5ghz Cpu 2gb Ram 120gb Hdd
Hello, My modell is unbearable noisy while cooling the videocard, what can i do? Thanks for the answers
  • David Cass
    David Cass Oct 24, 2012
    What is modell ?
  • joecoolvette
    joecoolvette Oct 24, 2012
    MSI T5250
    New Friend:
Hi
My laptop msi 6837D Intel Core 2 DUO CPU 2.0 GHZ, TYPE T5750
WAS PROBLEM WITH VERY NOISE FAN.
FOUR SCREW UNDER LAPTOP NEED TAKE OUT.
ON LITTLE GAP SHAPE U PUT SHORT SCREDRIVER AND TAKE OUT PLASTIC COVER, this plastic cover is having around little clips/ ears.
you WILL BE SEE FAN.
TAKE TWEEZER AND TRY CLEAN FAN.
FAN HAVING 4x very little screw- use magnetic scredriver.
Between sheetmetal and plastic insert 9cm long plastic pipe already fixed with WD 40 spray( or Astral ,...) , push him to side where is axis for fan , bottom side and spray only 0.5 s. Turn laptop back to normal position and oil will be slowly fallen down, still turning fan with finger for little while. Try again second time and will be enough oil for fan. Dont spray from air have to be long pipe touching axis with bearings.
IF is still very noisy the FAN so probably is too much worn and have to be replaced by new.
Posted on Mar 15, 2013
  • skurcak
    skurcak Mar 15, 2013
    Hi
    Between
  • joecoolvette
    joecoolvette Mar 15, 2013
    Thanks, skurcak! Appreciate you posting that!
Noisy shower/bath mixer unit
You have low pressure connect cold supply to mains
Sep 19, 2012 | Home
My microwave heats up for 3 seconds and then shuts off
Since you didn't mention the model number, I have to be kind of general.
This may be due to the internal cooling fan's not working or a "noisy magnetron".
For more on noisy magnetrons, see this FixYa solution even if your brand and model number is different.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Sep 29, 2011 | Thermador MBBS Microwave Oven
My whirlpool oven (model rbs305) makes a loud noise whenever it is on. I can't figure out if it's the fan, or just extremely loud.
I would suspect that the blower is noisy its what i would expect to potentially make noise ...if fits in the back of the control panel and it comes on to cool the control board each time the oven is on.
In case it turns out to be the blower thats noisy the part number for it is W10176670
GENE
Sep 10, 2011 | Whirlpool RBS305PD Electric Single Oven
One fan has become unbearably noisy. Need replacement for the processor cooling fan.
Hello there karlskad8.
Here's your geek-steer ...
Do NOT pass go, do NOT collect $200 ... you need to IMMEDIATELY replace that particular fan before you fry your CPU chip! Stop using it until you do!
If you plan on do-it-yourself, refer to your user's manual to possibly get replacement part order info. Otherwise, call a local PC shop and ask for the info.
I prefer http://www.coolerguys.com/ for all my fan related needs.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | HP Pavillion ZV6000 Notebook
Regarding noise
there some dust in ur's laptop fan
try to remove it. .
Aug 30, 2009 | HP Computers & Internet
Noisy fan?
This is normal.. It is keeping your computer cool when it gets too hot.
If you like this answer please rate it as a FIXYA.
Jun 06, 2008 | Acer Aspire 3050 Notebook
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
GE Side-By-Side Refrigerator Model GSS 23QSTA SS
Apparently the digital read out sensor is bad. 45°F is to high for safe food storage. The fact that the milk spoils is another factor which speaks on its own that there is a temperature control problem. There is no "defroster fan". There are two fans in the unit. One is the air circulation fan located inside the freezer compartment and the other is the condenser fan for cooling the refrigeration system. If you had called for service in the first year it would be covered by warranty with the exception of the service call charge. After the first year ends electrical and control problems are not covered. If the evaporator fan in the freezer is noisy there is something wrong with it. It could be the source of your whole problem.
Mar 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
MSI Ultra Ms-6837d Ms-1637 15.4" Notebook T5250 1.5ghz Cpu 2gb Ram 120gb Hdd Logo
141 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
