Question about Nintendo Professor Layton & the Curious Village Games for DS
I,m stuck on no 97 can u help
Run out of options
97 Buick Riveria Blower fan blows hot air even when off, display ahowa nothing, have to pull fuse to stop blower
In 97 GM did wire it to run continually. But not hot air. Most likely mode door is stuck or control faulty (vacuum or bodin cable)
Apr 07, 2014 | 1997 Buick Riviera
How do you know if thermostat is stuck on a 97 nissan maxima
None of what you replaced was necessary
Who replaced those parts & why,no testing?
If the thermostat is 6 or 8 years old, you just
replace them on all your cars
Jun 21, 2012 | Nissan Maxima Cars & Trucks
I got a 97 ford thunderbird lx when i try and srart it it turns over but wont start?
sounds lie a bad fuel pump. replace your fuel filter first, if that doesnt work then you may need to drop the fuel tank to get the pump out.
Oct 28, 2009 | 1997 Ford Thunderbird LX
97 Jimmy is having vacuum problems
No. A 97 Jimmy doesn't have points either. Only way that works if it's not original motor.
Sep 16, 2009 | 1997 GMC Jimmy
Need a user manual for my Euro-Pro Model EP 97 Steamer. Never been used...been stuck in it's styrofoam packing for 5 years...no instruction book...HELP!
Hi
Thanks for using FixYa. You can download the manual from the shark website from this link---
Euro-Pro Model EP 97 Steamer Manual
There is also a manual for a similar model--
Euro-Pro Model Steam cleaner Manual
Once you are there, please sign up and register your product. AFtre this click on the manuals tab in the bottom and then you'll be able to download the usr& instruction manual for your EP 97 steam cleaner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Sewing Machines
97 four runner 4cyl. Engine fan runs all the time
If the A/C is on, it is supposed to run all the time. If the A/C is off and it is still running all the time, then check the thermal relay. It is probably stuck in the closed position. The fix is to replace it.
Aug 09, 2009 | 1997 Toyota 4Runner
Recent viewed documents in Word 2007 grayed out Administrator fix
http://blogs.zdnet.com/microsoft/?p=2616
this is free download
I am running MS Office 97 and was unable to reconstruct you problem
Hope this download helps
May 07, 2009 | Computers & Internet
No heat in 97 mercury villager
your heater core may be getting blocked up, or the thermostat may be stuck open at times. you have a few options here, option 1 and 2 cost about the same, option 1: have the thermostat replaced just so you know its working properly, a 97 will most likely not have a telltale way of knowing if the thermostat is bad or going bad. option 2. have the cooling system flushed at a shop. this will try to clear out and debris in the cooling system that may be blocking passages or the heater core. option 3 is the most expensive. have the heater core replaced, the heater core is what provides heat to the hvac system in the dash. a few other things to check would be vacuum lines/actuator/temperature door on your hvac system.
Feb 16, 2009 | 1997 Mercury Villager
97 850 with stuck hood
The whole mechanism is run by two cables. The first from the hood release latch to the left side hood catch. The second from the left hood catch to the right one.
First look and see if the second cable is disconnected from the left hood catch. if it is just pull it and the right should open. If not...
Have somebody with skinny arms to reach up from under the car and manually pull the lever on the right hood catch.
Hope this helps...
Sep 19, 2008 | 1997 Volvo 850
Nintendo Professor Layton & the Curious Village Games for DS Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
