Question about Kitchen Ranges
GW74X hotpoint double oven,for the last few months each time I use the main oven the ignition button clicks none stop it used to stop after a while untill about a 2 weeks ago it's constant everytime I use the oven,now the 2 little gas rings don't spark with the ignition,please can anyone help its driving me crazy each time I cook, it's very frustrating .thank you
catriver
  • 878 Answers
SOURCE: Igniters won't stop poppong
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. Catriver..post back.
Posted on Sep 11, 2006
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
fridgetech
  • 473 Answers
SOURCE: Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Posted on Oct 13, 2007
Eddie Rentas
  • 59 Answers
SOURCE: hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
frcs68
  • 1605 Answers
SOURCE: GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Posted on Oct 23, 2008
Hotpoint uy46 style line stainless steel, 2 year old, main oven fan takes 20 to 25 mins to start then runs too slow and some times stops, but the heat element is glowing red and very hot
The symptoms you describe are an indication that the fan motor is in imminent danger of breaking down altogether.
You need to replace it as soon as possibe, otherwise you will end up with the element burning itself out, thus doubling the cost of repair.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint UY46 Style Line Stainless Steel...
Oven makes a clicking sound after it has been baking for 2-3 hours.
Dear Robbird:
You need to give more detail---- brand. model, age, gas or electric, speed or repetitiveness of the sound; is it a click or a tick sound ? I will assume it is gas. Is the sound the same as when you start a top burner and you hear the tick as it is lighting? Or, is it a click the is slower and you hear it from somewhere inside the oven ? It could be the metal body expanding as the outer parts of the oven get hotter with long hour usage. I n the is case, there is nothing to do or to worry about. Does the sound stop when you turn off the oven or does it continue for a while. Naybe you can resubmit with better info to get a more precise diagnosis. Wait to hear from you, Macgivor.
Oct 04, 2009 | Five Star TTN280 Gas Kitchen Range
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven ignites by itself
Any chance that the plastic knob was cracked and not really turning the shaft of the thermostat?
What did you find the problem. I know this response is 2 months after the last post above.
Eddie
Jun 08, 2008 | Hotpoint RGB745 Gas Kitchen Range
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint 30" self cleaning gas range with sealed burners - no bake
It may be the ignitor, they can crack and you wouldn't even see. Good news is they are cheap ($5-20) and they are usually easy to replace. But before you replace it...
When set to bake, does the "oven cycle" light come on? If not, that means no power is being sent to the ignitor. Reason? There is a switch in the oven latch, to make sure a) latch must be closed for cleaning cycle and b) latch must be unlocked for baking. On mine, the switch button gets stuck, so even when the latch is unlocked, it thinks it is locked and will not allow the bake cycle to proceed. Cycling the latch a few times may free it, otherwise you'll need to replace the switch (not that hard but a bit of a pain to get to).
Nov 15, 2007 | Kitchen Ranges
Microwave won't work; timer word stuck on screen
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Our site is linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JVM1340AW/BW/WW Microwave Oven
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
