Rinnai TCW-15CA control panel flashing/beeping
  • Dan Gresham Oct 24, 2012
    The TCW-15CA is an electric panel heater. When power is applied to the unit the orange and green lights flash and it beeps constantly.
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
What does code 79 mean for the rinnai RU98i? It is beeiping and flashing 79
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Jan 09, 2013 | Rinnai Water Heaters
I have an Rinnai Avenger 25TR heater. The problem is that the heater ignites, it starts, but then it turns off. A red light then flashes and the number 13 also flashes in the bottom right hand corner of...
Paul, the Error Code Fault 13, indicates a Combustion Control Fault. This could mean, not enough gas for safe combustion or to much gas for continued operation. In any event, if requires a service call from an authorized Rinnai Service Technician to solve.
Just in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helped you.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
My Rinnai R85 heater will not heat; it is leaking water. I installed the unit 24-26 months ago, and had no problem until today. The automatic starter will engage but the flame (pilot) will not ignite. The...
I just fixed a leaky R85. Fortunately it's the bypass valve, not the heat exchanger. Did your heater freeze up in this snow storm? Unplug the power, open the cover and see where it leaks. If water comes from the top, means crack on the heat exchanger, then it would be too costly to replace. If you can see the water gushing out of a valve, on the bottom of the heater, then it's an easy fix. The valve is fixable, you don't have to replace it. But still need to find out what causes the flame fail (error 12). I suspect the igniter got wet, dry it with a towel after you take out the valve. Removing the fan first will give you more room to work inside.
Feb 09, 2010 | Rinnai Digital Remote Water Heater Control...
I have a Rinnai tankless gas water heater and this things beeping and flashing 12 everytime we turn on the hot water the water will get hot but you have to wait for it to stop beeping
Error 12 is failed ignition - this can be caused by many things, but normally a low gas pressure, or no gas pressure upon ignition.
Try turning the hot tap on very slowly till till the control shows burner is lit. Then turn it on faster. If it stays going with no error, you might have a faulty regulator, not opening fast enough to meet demand. Especially common with lpg models,a lot rarer on natural gas.
Oct 27, 2009 | Rinnai Water Heaters
This things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Jul 28, 2009 | Rinnai Water Heaters
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
I have beeping but no flashing lights
what is the beeping off and does it have batterys
Dec 29, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
