Question about Acer D270-26dkk Aspire One 1600 Mhz Intel Atom N2600 1024 Mb 1 So
Chkdsk runs at boot-up - Acer D270-26dkk Aspire One 1600 Mhz Intel Atom N2600 1024 Mb 1 So
  • anti_aunty
    anti_aunty Oct 28, 2012
    Dear Mr./Mrs. aditya19818, please stop wasting my and others' time; you do not seem to understand the problem at all, and your suggestions are simply worthless rubbish. The machine is brand-new, and has not been abused. Re-installing the operating system is an extreme solution and is here not applicable. You could try getting something *useful* to do. I wish you a good rest of the day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Its problem from biose setting start laptop then just press f12 util you find a blube screen with some setting search in its default setting then default it and press f10 for save press y then enter
Posted on Oct 24, 2012
  • 2 more comments
  • anti_aunty
    anti_aunty Oct 24, 2012
    Thnx; using machine at the moment so can't try just yet - but what option in bios setup needs changing? The chkdsk does not run *every* boot-up, but takes 15mins and no errors found.
  • aditya19818
    aditya19818 Oct 28, 2012
    press f12 then you find some option , select hard disk option then press enter if not work insert a xp or win 7 cd or dvd then restart and press f12 jusrt now ( check that f12 option when you start after 1 or 2 second you see some option below the screen ) f12 for boot option then select cd/dvd option and press enter for reinstallation operating system
  • anti_aunty
  • aditya19818
    aditya19818 Nov 13, 2012
    brother most of all problem from operating system and one thing more you not write your problem correctily it also problem from har disk one make hard disk 'zero fill' you problem is notbig problem its small problem we solve that problem you write so write full problem details
Status 0xc000000f
You should be able to create a boot able stick for this kind of issue.
Sounds like you have hard disk errors. Open the Command Prompt when the Installation DVD Loads and type the following commands.
chkdsk /r c:
chkdsk /r d:
chkdsk /r e:
chkdsk /r f:
.etc until you get the message that the volume could not be opened for direct access. For any drives that do not give the message:
"Windows has checked the file system and found no problems"
run chkdsk again as above. In other words, if it says:
"Windows has made corrections to the file system"
after running the disk check, run the disk check again.
I realize you may only have one disk show up in Windows explorer, but you may have more than one disk through recovery options. This is because the system creates a hidden boot partition (which will be C: in recovery), you may have a recovery partition for your PC that is hidden (which will be D: in recovery), and you will have your primary Windows partition (which may be E: in recovery). A custom PC will likely have at least C: and D: to scan.
Nov 01, 2013 | Acer Computers & Internet
Windows 7 will not start
First you need to try safe mode and check if you are able to boot to the system....
If not then ...
Note this issue is caused due to the boot file corruption and in order to troubleshoot this issue we will run chkdsk from Win RE (Windows Recovery Environment )mode and check for the issue, to do that follow the below steps.
To run check disk, you have to have Windows 7 DVD, boot the computer to Win RE from the elevated command prompt, and try to do a CHKDSK. You can follow these steps to run CHKDSK :
1) Use the Windows 7 DVD to start the computer in Windows Recovery (WinRE).
2) In WinRE, open a command prompt. To do this, follow these steps:
On the Install Windows screen, select the appropriate Language to install, Time and
currency format, and Keyboard or input method options, and then click Next.
3) Click Repair your computer.
4) Click the 7 installation that you want to repair, and then click Next.
5) Click Command Prompt.
At the command prompt, type the following command, and then press ENTER:
chkdsk drive: /f and chkdsk drive: /r
source link
Jan 14, 2013 | Computers & Internet
My sony viao VPCEA33EN does boot up.when I press the on button the starting windows r showing as usual but after that the screen goes blank ..please help ..I did try the safe mode but same result ..
boot from your windows cd, go into recovery console and run chkdsk /r.
if you don't have a windows cd then use hirens boot cd to run chkdsk
Apr 02, 2011 | Computers & Internet
Booting problem.....
if you still having booting problems, you can do this suggested steps:
Insert the Operating System CD before pc reboot
Try to boot to safe mode with command prompt by pressing F8 repeatedly , select "safe mode with command prompt " option then hit ENTER, then run this command ...
Then follow these guidelines:
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Hope this help...
Apr 18, 2010 | Lenovo IdeaPad Y510 Notebook
Dell 530 won't boot up. Blue screen tells me I need to run CHKDSK /F. I can't get in anywhere to run it.
Try booting up in safe mode COMMAND PROMPT ....
Type CHKDSK /F
CHKDSK cannot run because the volume is in use Type Y and push enter it will start on the next startup...Restart the computer... If that doesn't work take the hard drive out and connect it to another computer and run it on that...
Apr 09, 2010 | Dell Inspiron 530 PC Desktop
Need help getting pass the blue screen
Here, here, here and here are some excellent resources that will help you to troubleshoot the stop error codes (blue screens). If you reply with the exact code # you are getting, we can give you more detailed help, but you should be able to run chkdsk from the recovery console (if you have it installed, it would appear as a boot option (breifly) when you boot your system, or by pressing F8 as it boots up. For more info about recovery console see here and here. You can also run chkdsk from an installation cd if you boot the system from the install or recovery disc instead of the hard drive. See instructions to run chkdsk here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | IBM ThinkPad T23 2647 Notebook
BSOD says boot partition is full, when it isn't
hello
try to boot in safe mode.(press F8 after bios bootup)
if that doesent work run chkdsk.(boot from windows cd and choose R(repair mode) go to the console and write chkdsk /R let that run and try to restart when its done.
Feb 23, 2009 | Lenovo ThinkPad R51e Notebook
Acer Aspire AST135-U-S3104 Won't boot up
thats great. let me know if anything pops up.
Jan 08, 2009 | Acer (AST135-U-S3100) PC Desktop
Computer wont recoginze scan disk
scandisk is no longer a utility used by windows 2000 and beyond.
Instead, use chkdsk. You run it from a command prompt window. Running it will do a diagnosis. Run "chkdsk /f" to actually fix errors. You may need to reboot to have it done at boot time.
Dec 08, 2008 | Computers & Internet
Acer D270-26dkk Aspire One 1600 Mhz Intel Atom N2600 1024 Mb 1 So Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
