Question about Toro Power Lawn Mower
No spark on toro ccr 2000 single stage snow blower
Clean carb and checked spark plug I pit screwdriver in to plug wire to check for spark and I didnt get a shock
    Problem Solver:
  • 11 Answers
The kill switch cable on the handle my be broke
Posted on Oct 24, 2012
HansPP
  • 2510 Answers
SOURCE: Toro, 21" inch push mower
If the engine compression is too low, it will have problems starting or not start at all, and these seem to be the symptoms you are describing. An easy test is to pour some oil into the cylinder and see if that increases the compression. If this makes a difference, you will need to replace the piston rings and at least hone the cylinder, depending on the wear in the cylinder bore.
You can also try spraying some easy start into the intake and seeing if that makes the machine run for just a short spurt. If it does, you could have a problem with the carb not supplying fuel due to something like a blocked jet or irt in passages etc.
Posted on Jun 18, 2011
  • 108 Answers
SOURCE: can't keep my snow blower running under load,
there should be an ajustment screw on the carb. turn it all the way in don't turn it hard then turn the screw back out 1 1/2 turn to start out with then after runing turn till it runs evenly.
Posted on Dec 22, 2009
motor1258
  • 6674 Answers
SOURCE: I HAVE TORO SNOW BLW. MO.# 38195 CCR 1000C 3 H.P.
Some have a circuit breaker that cuts out when too much current used when trying to start too much. Usually when it cools, will kick back in. Have you tried disconnecting battery temporarily, if just letting it sit doesn't do it? PS. Sometimes a little shot of WD-40 into carburetor will help start it if it's been sitting quite a while.
Posted on Dec 29, 2009
heres2maine
  • 84 Answers
SOURCE: Have a Toro LX 465 lawn tractor, won't start;
Could be your coil. Might be bad or it went out of gap. Gap is .10
Posted on Jul 10, 2010
SOURCE: I have a Toro Model
check your mower for interlock switches that might interupt spark for safety reasons.
A chute switch or something like that. Check your owners manual for troubleshooting.
Unplug the keyswitch and try pull starting to rule out a bad switch.
If it still doesnt have spark you might need a new coil.
The coil is right under the recoil cover and are fairly cheap.
A set of hand tools and $30-50 for the part should do it.
Good luck and be careful.
Posted on May 04, 2011
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
Will not start.but backfires..why?
Clean the spark plug, it might be dirty causing misfire.
Timing might be off, take to repair shop for this.
Feb 13, 2015 | Toro Power Clear 418 ZE - Single Stage...
Engine surging Toro 621 38452 unless on half choke
you have dirt in your carb blocking fuel to engine. clean carb
Apr 09, 2014 | Toro 38452 - Power Clear 621E Electric...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Snow blower wont start
clean the fuel out and the carb , make sure you are getting spark close the choke to start then shut if off or it will foul the plug
Feb 17, 2014 | Toro Snow Blowers. Power Clear 18 in....
Where is the spark plug
pull the back cover off it is there follow the big fat wire which is your coil takes you to the plug , 13/16
Jan 25, 2014 | Toro Snow Blowers. Power Clear 621 QZE 21...
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
How do I clean carburetor
check out this YouTube video for cleaning a single stage snowblower carb.
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
Engine surging
sound like the carb gasket is bad sucking air clean the carb out if continues replace the carb , but clean it out and the plug also
Dec 10, 2013 | Toro 38452 - Power Clear 621E Electric...
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Toro Power Lawn Mower Logo
252 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
