Question about Lexmark X2350 All-In-One InkJet Printer
Printer Lexmark x2350 will not allow printing
It keeps showing the "print alignment" page when I try to access printing, although I have already printed alignment pages twice, but when I try to print alignment through that popup, it says cannot print while printer is busy, but while that popup is there the printing cannot continue.
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
  • 684 Answers
SOURCE: Lexmark 6570 printer won't print the first page
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X6500 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Posted on Jan 28, 2009
  • 14 Answers
SOURCE: printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Posted on Apr 24, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: printing blank pages
    For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
    Posted on Apr 09, 2010
    • 22 Answers
    SOURCE: i have a Lexmark Printer z2400. i have a lexmark
    that can be happened with some problem of cartridge or cartridge holder.
    if you can check the printer with your older empty cartridge, and you can see
    the different error message with that , it says your printer is OK.
    and have some problem with your cartridge.and need to replace it.
    if you can see same message with your old and empty cartridge,
    you can clean both of cartridge the connecting pads ( in printer cartridge holder and
    back side of the cartridge ) using by IPA and check again.
    if had corrosion or some ink swallowed problem , can be clean with that.
    after that if you got same result, you need to check your cartridge with
    another printer or your printer with another good cartridge.
    Posted on Jan 03, 2011
    Testimonial: "I put in the older empty cartridge, and the error message stopped. At least I'm only out of the price of a new black cartridge and not a new printer."
    Lexmark p4350
    Try to align the cartridges using the Lexmark software installed on your computer to fix the problem. Please follow the steps below:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark P4300 Series folder.4. Select Lexmark Solution Center.5. Select Align to fix blurry edges. Your printer will then print a page that will align your cartridges.
    Try to print your document again to verify that the problem is fixed.
    Dec 27, 2011 | Lexmark P4350 All-In-One InkJet Printer
    I have a lexmark x2350 (all-in-one,2300 Series).In the troubleshoot ,said printer status ready.But when i try print,or take a print page text,i hear:printing started,printing complete,but the machine don`t...
    Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/qQJd8g. Select your operating system to download the file.
    If that doesn't help, follow the steps below: 1. Disconnect the printer from your computer. 2. On your computer, go to Control Panel > Printers and Faxes. Delete the Lexmark X2350 print object. 3. Reboot your pc. 4. Once the pc completely boots up, reconnect the printer into the pc. Wait until your pc fully recognizes the USB connection. 5. To ensure the print object has been successfully created automatically. Go to Control Panel > Printers and Faxes. You should see a new Lexmark X2350 print object in the list. 6. Try to print again.
    Jul 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
    Status idle + Test page onl shows top (reddish). Rest is blank.
    Check that you're not out of "blue" and/or "black" ink.
    For example, no "green" on the page means that the printer did not mix "yellow" and "blue".
    Also, the "rest" of the test-page should be "black", if any black ink is available.
    Jul 03, 2010 | Lexmark X2350 All-In-One InkJet Printer
    Hi have a lexmark x2530. printer does not print word doc pages. will only print alignment page.
    Please follow the steps given below:
    1. Please Load a plain paper.
    2. Press and hold the "Scan" button for three seconds.
    3. An alignment page prints.
    4. Place the alignment page onto the scanner glass.
    5. Press the "Scan" button.
    6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
    May 06, 2009 | Office Equipment & Supplies
    My Lexmark X2350 all in one printer wont scan
    Reinstalling drivers often solves this kind of problem.
    Here the driver download page for this printer: download
    a driver?
    Apr 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
    Printer wont load paper
    To align the color cartridge, simply try taking the cartridge out, and putting it back ini. Most often on Lexmark printers, this will bring up a message asking if your cartridges are new or old and of what number they are. after this menu you will likely be forwarded to a printing alignment page
    Oct 04, 2008 | Lexmark X2350 All-In-One InkJet Printer
    My printer won't work and I'll need to use it soon!!
    Go to Lexmark.com and check on a vista update, most of the older software simply does not work with vista.
    Aug 11, 2008 | Lexmark X2350 All-In-One InkJet Printer
    PRINTER ONLY PRINTS CODES, NO IMAGES
    you need to re-install the driver http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X2350
    May 20, 2008 | Lexmark X2350 All-In-One InkJet Printer
    Lexmark X2350 printer problem
    Usually the light blinks if you have started a print job and run out of paper...it's trying to get your attention to insert more paper before it can continue. Check and see whether there are any print jobs that weren't able to conclude and delete them. Go to 1) Start, 2) Control Panel, 3) Printers and Other Hardware, 4) View Installed Printers, 5) Lexmark 2300 Series. When you double click on the Lexmark Printer Symbol, it will open up a smaller window which will show you whether there are any print jobs that are waiting to print. If there are any, delete them. Hopefully this will solve your problem.
    May 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
    Lexmark X2350 paperjam/top cover sensor problems
    I thought I got all FOD out of my printer, till I turned it up side down.
    Pencils apparently find the x2350 very comfortable.
    Nov 30, 2007 | Lexmark X2350 All-In-One InkJet Printer
    Lexmark X2350 All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
