Question about HP Office Equipment & Supplies
Camera memory card not connecting eith printer
When I hook up NEW LEXAR professional SDXC class 10 64gb 400x memory car into my hp 3210xi printer,all I get is" memory card error."...
    Problem Solver:
  • 6 Answers
Is your memory card lock. if so, slide the bar back up. also try inserting the card with a little force, but before you do so, blow on the card to make sure no dust is on it.
Posted on Oct 24, 2012
RichardThor
  • 11 Answers
SOURCE: I have a HP Photosmart
You are using a new camera with an old printer.
Check the following:
- Try using a 1 to 2 GB SD card. The printer may not be able to hande one this size.
- Try taking a photo, in a smaller resolution, and save as JPG.
- Try plugging in the camera to the printer and print from the camera.
And the best option, is to transfer your photos to your computer, and print from there.
Take a look at a program called "Thumbs Plus" it has worked well for me. http://www.cerious.com/
If you have lost your manual, see: www.HP.com/Support for other answers.
Posted on Jan 01, 2009
SOURCE: Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Posted on Feb 09, 2009
SOURCE: hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Posted on Aug 07, 2009
prashanthcl
  • 460 Answers
SOURCE: memory card error on hp psc 1610
it is a logic card problem.so you can checked it from vendor.
Posted on Sep 07, 2009
  • 161 Answers
SOURCE: memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Posted on Sep 10, 2009
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 | Cameras
Volume not contain recognized file
What device wrote the files to the card? Was it a digital still camera, video camera etc.
Also, have you tried to repair the disk using CHKDSK (Windows PC) or Disk Utility (Mac)
Dec 30, 2013 | Lexar Professional 400x 16gb Sdhc Card...
Lexar 4gb sdhc memory card error
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
Jul 15, 2013 | Lexar Memory Card Sdhc 4gb Class 4
How to access lexar memory card without loker,my memory card loker has been breaked
If it's still a usable card, I would suggest just placing it back into your camera and then connecting it via USB cord.
If that doesn't work, check if your computer has a slot for SD cards. If it does, try placing the card in one of the slots gently.
Sep 15, 2012 | Lexar Professional High-Speed 2GB Secure...
Whats a good memory card for the cannon powershot A410
You can use any MMC or SD card. Be careful not to get SDHC or SDXC cards, they won't work in the A410. The brand doesn't matter, though I'd stick with the major brands, like Lexar, PNY, and SanDisk. The speed doesn't matter much either, so I wouldn't waste money on fast cards.
Aug 29, 2011 | Canon PowerShot A410 Digital Camera
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
67 people viewed this question
Seeker5211
Seeker5211
