Question about Dryers
Fan is not rotating - Dryers
    Problem Solver:
  • 6 Answers
Is your fan giving off a humming sound. sound like your motor is gone. need a new fan. sorry. is it a celing fan.
Posted on Oct 24, 2012
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
Maza 323 radiator fan rotating direction
the direction of fan rotation will be on the motor body but check that th curved edge ( leading edge) of the fan blade is facing the radiator and that air is being pulled through th radiator. THe motors are dc operation and can spin in both directions and the fans themselves are made to fit in front of the radiator( a/c fan) and blow air through the radiator. So checking these points is necessary
Jan 19, 2013 | Mazda 323 Cars & Trucks
HOW TO FIX ERROR 805 006 ON CANON IR 400
Laser scanner motor cooling fan 2 (FM6)
The fan motor does not
rotate at a specific speed 5
sec after it has started to
rotate.
The fan motor rotation
deviates from a specific
value for 5 sec or more
while it is rotating at a
specific speed.
Dec 18, 2012 | Canon imageRUNNER 400S Copier
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
Can not find directions to reverse fan rotation for summer
it should be a simple slide switch on the side of the housing that moves up and down to change the direction of rotation of the fan motor and blades. look at the manual that came with the fan to make sure it has this feature but i personally have never seen a fan without one.
May 30, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Can't reverse ceiling fan rotation
some fan models will only spin one way!! If there is not a switch on the side cover of fan.
Feb 04, 2010 | Emerson CF2600PW Raphael Pewter Ceiling...
1 and 4 fan problem
This might happen when it detects a non-functioning fan (to preserve all other components).
We've had the same problem on one of our server, one fan wouldn't start (needed more current to start it)
We had to replace the motherboard on server to make it work, since this one got it power from the MB.
A temporarily fix was: Pop fan 4 out, give it a push so it rotated and quickly insert it before it stopped, hope it won't be stopping until you receive a new motherboard.
Sep 03, 2008 | HP Compaq ProLiant DL380 G3 Server
Dryers Logo
37 people viewed this question
Top Dryers Experts
