Question about Canon PIXMA iP1600 Printer
E. 5100, green orange... (4) When lid lifted ink stays on rt.
Power was unplugged when the ink was on the left (replace) side. After turning off and restarting printer iP-1600, the message for four flashing lights says ink may be out. But when the lid is opened, the ink stays on the right, so I can't check if it is loose connected. When I turn off the printer and restart, the ink makes one right to left and back motion, followed by a clicking sound like a "switch". Then, the green orange green orange lights flash (four total each set).
Is this a sequencing error? If so, how can I reset the defaults. JAA
  • armisteadja Jan 03, 2009
    Dear Ginko: Success! The problem was that little white Nylon hinged piece, with the wire whisker spring. I was mopping around in there with cotton on a stick and must have pushed that part too far toward the near side for the little spring to make it work. The part looked out of place, so I pushed it down and the ink carrier freed up to slide on the track. Thanks for being a genius!
    VTY,
    John
    Genius:
  • 1,239 Answers
Hi it is simple problem  one of the ink cartridges wasnt sitting properly so have pushed it in. correct it
Posted on Jan 02, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 02, 2009
    http://www.canon.com/motherboard/prob676... herre the solution.
    try this methode
    Methode 1
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting formenu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
    lights alternately in
    orange and green, starting with orange.)
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection
    President:
  • 2,110 Answers
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
  • Sibananda Jena
    Sibananda Jena Jan 02, 2009
    1) Enter SERVICE MODE.
    By pressing Menu, Copy, Scan, Copy, Copy
    2) Select TEST MODE.
    3) Select [8] in PRINTER TEST TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [Set] key.
    7) Press the [Stop / Reset] key (returning to the state of 3)), and then press the [ON / OFF] key
  • Canon Master
  • 19,396 Answers
Try unplugging the power cable again and playing with carriage, I think the problem may concern mechanics, in that case reset won't help.
  • Ginko
    Ginko Jan 02, 2009
    The clicking sound may be the traction belt slipping, and the carriage may be stuck on a side.
    Start by unplugging the power cable,and try the reset and the powercycling suggested.
    If that does not work, it means that there is a fault, and the print must be taken apart to fix the problem.
Printer is running out of ink. To put new cartridge in I lift the lid and normally cartridge carrier moves over to left allowing replacement of cartridge. Today no movement---why? Green light is flashing...
Hi there.
It's probably jammed by dirt. Unplug the printer, move the carriage out of the way and clean thoroughly the metallic rails the carriage runs to using a cue tip.You might have to move the carriage multiple times to clean it totally. Finally spread a little fine grease over the metallic rail and again move the carriage from side to side. Now plug it in and try using it.
Let me know what happens.
Sep 11, 2011 | Epson Stylus C46 InkJet Printer
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
Canon ip2770 error 5100 and 5200
How to Reset Canon IP2770 Error 5100:
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps.
Turn off printer
Remove both the cartridges from the printer
Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
Return the cartridges
Turn on the printer.
Error will be removed
How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use.
Other Ways Reset Canon iP2770 error 5200:
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal. (Source: from all existing sources)
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 27, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
What do errors messages 5100 and 5C00 indicate when offered by my Canon Pixma iP90?
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
5.Turn off the printer.( it must be turn off) then turn it on again
Nov 19, 2010 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber is full
Hi Good day!!!
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.
Following is the procedure to reset the waste ink counter for the Canon Pixma MP150
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 19, 2010 | Canon i850 InkJet Photo Printer
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
How do i fix "Waste ink full" to resume printing
Hello there
Canon Pixma iP4200, Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction. :
Look at the table below:
· 1 led- Orange – Service test print 1 times – Orange – Service test print
· 2 led – Green – EEPROM information print 2 times – Green – EEPROM information print
· 3 led – Orange – EEPROM initialization 3 times – Orange – EEPROM initialization
· 4 led – Green – Waste ink counter setting 4 time – Green – Waste ink counter setting
· 5 led – Orange – Destination setting (Press Power > Press Resume 3x) 5 times – Orange – Destination setting (Press Power> Press Resume 3x)
· 6 led – Green – Print head deep cleaning 6 times – Green – Print head deep cleaning
· 11-13 led – Orange, Green, Orange – Return to menu selection
· 14 led – Green – Left margin correction 14 times – Green – Left margin correction
  1. Turn off the printer POWER button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Mp600 error 6A00
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
Dec 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Canon PIXMA iP1600 Printer Logo
47 people viewed this question
old marine
old marine
