Question about Vizio E191VA 19 Inch Class Edge Lit Razor LED LCD HDTV
My vizio model E191VA remote doesn't work.
My remote worked out of the box -- I use the TV as a monitor for my computer but after a week the remote only worked to mute or unmute the TV. Every button did this. Now the remote dosn't do anything at all.
    Problem Solver:
  • 6 Answers
Sounds like a factory default
Posted on Oct 24, 2012
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
  • 176 Answers
SOURCE: cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Posted on Jan 19, 2010
SOURCE: i cant unmute my 42 vizio plasma , i dont have
hi ! i have here one code for your TV, you could try it 0081 hope it helps. goodluck!!!
Posted on Jun 03, 2010
bshldn
  • 736 Answers
SOURCE: Just got a Vizio 55"
Based on my understanding of what you have written you are able to connect your directv remote and the television in some small way albeit just a volume bar appears on the screen. If you are certain the volume bar is coming from the television and not the set top box then you've most likely ruled out the television being the problem. Even though the directv remote does not turn the televison on and off that doesn't indicate the television not working properly because it's all in the codes you enter. The simplest way to check the sound on the television is to connect the directv set top box to the television with composite or component cables including the red and white audio ones provided that your box is not a basic coax to television connection one. Then you should be able to use the source/input/av/video/aux button on the television to choose the proper input to display your direct tv set top box. If you still do not get sound try connecting the box to a different input on the television if possible. You can also try connecting a different device to the television i.e. a dvd player.
If the remote that came with the television has a light at the end of it look at that end through a cell phone camera. Press a button on the remote control and you should be able to see the light blinking. This will indicate that the remote is working, and you cannot see this with the ***** eye.
Posted on Aug 11, 2011
caroldon
  • 17129 Answers
SOURCE: channel up/down button on remote for 37" vizio tv
It is possible that the pads are worn out or there is damage on the main board, possible carbon track failure . you might need to reform the tracks or use a remote control repair kit to retrack. Also in some cases the controller IC can be defective as it fails to detect the selected port.
Please try this link for some tips:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Oct 04, 2011
How to open back cover vizio e191va
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Disassemble procedure to many popular brand TVs and others are given with illustrations.
May 18, 2014 | Vizio E191VA 19 Inch Class Edge Lit Razor...
Can i turn my vizio m190va tv into a computer monitor?
Unfortunately. the HDMI port on the M190VA does not interpret the signal from a computer. The HDMI signal from a set-top box is different than that of a computer. You need to use the VGA port and the PC audio in on the TV; if your computer doesn't have a VGA port, use a DVI to VGA adapter or other appropriate adapter. You will need a 3.5 mm audio patch cable to use the TV's speakers. See page 25 of the M190VA manual here: http://store.vizio.com/documents/downloads/hdtv/M190VA/364User%20Manual.pdf .
I wish that I had better news for you.
May 08, 2012 | Vizio M190VA 19 Class Edge Lit Razor LED...
Our remote died to our Vizio ....checked batteries, etc...have been having problems for a while...bought a new universal Vizio remote...keyed in all the numbers....last four work...but still is not...
New TVs and older ones, even recent model changes usually have different codes. Read the new remote closely. there is a section about finding the code manually. It is a pain, but works.
May 30, 2017 | Televison & Video
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
I have a Vizio e260mv, using it as a computer monitor. i came into work today and turned it on and all i get is the Vizio logo. it will not go to a monitor status or even a blue screen as when there are...
1. Make sure that the cable in tight. 2. Make sure that the TV is using the correct input, I'll assume it's on VGA input. Some Vizio TVs call the VGA input RGB. 3. Turn the computer on and see if the post shows up. 4. If it doesn't, you'll have to use some other equip to test if it's the TV or the PC. Good luck.
Aug 09, 2011 | Televison & Video
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
What is the remote control tv code for a Hannspree 28 inch tv using Verizon Fios? ljs
if you go to this online site you should be able to find your codes.
http://www.hannspree.com/us/common.aspx?mid=6172
May 15, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Remote that came with TV doesn't work. are there codes?
It's possible they put the wrong remote in the box. People in the packaging dept can make mistakes.
I have a copy of your manaul. It says nothing about programming the Vizio remote for Vizio TV.
I would call the 1-877-698-4946 support line.
They should send you the correct remote.
You'll need to give them info.
1. Model numbel of the TV
2. Serial number on the TV
3. Purchase price of the TV
4. Model number on the back of the remote
May 10, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio E191VA 19 Inch Class Edge Lit Razor LED LCD HDTV Logo
303 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
