Question about Acer Extensa 5420-5687 Notebook
What is load setup default
Just replaced my old hard drive with a new one
  • Acer Master
  • 27,725 Answers
So you reinstalled the operating system ? then returned to set faisafe or optimised defaults
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Posted on Oct 24, 2012
I have a northgate protek computer and get an error that win32 is corrupt computer will not start up. How can I access to restart program. Tried to start by pressing F9 to reboot.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
hope this helps
Mar 27, 2011 | Northgate Computers & Internet
My laptop won't boot up when i go into boot up options at the very beginning and do a primary hard disk self test the message comes through that says #10008 replace hard disk
or
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 13, 2011 | Computers & Internet
Screen stays black and power button is flashing and cannot turn off
unplug from the wall let it cool down 1/2hr
test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
then reboot
during the boot process you will see on the screen to press delete to enter setup
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might hope this helps
Dec 03, 2010 | Computers & Internet
How do i reboot my computer to factory setting?
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
if you are having problems with your computer heres a tip
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
hope this helps
Nov 27, 2010 | Computers & Internet
Computer freezes i try to reload,then i get error with black screen .
or
BIOS scroll to PnP/PCI configurations the default is disabled
select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
hope this helps
Nov 08, 2010 | Computers & Internet
BOIS DOES NOT COMPLET STARTUP
hope this helps
Oct 25, 2010 | ASUS Computers & Internet
On my laptop i have a problem with the blue screen. When I turn my laptop on it loads for a few seconds then it gives me the blue screen, what do i do?
hope this helps
Oct 24, 2010 | Computers & Internet
I purchased a new hard drive and am attempting to load window but the hard drive doesnt seem to be detected. when i put the old hard drive back it boots... but with the new hard drive i get a curser in the...
Plug in the new drive. Be sure to check the jumper setting is set as "Master" The manual should explain this. Most drives are set to this by default. Before windows boots Press either F8, F7 or F12. This should get you to the BIOS screen of your motherboard. From there your should be able to navigate to setup the drive. The screens are pretty easy.
Nov 23, 2009 | HP Pavilion a1210n (ED895AA) PC Desktop
My gateway MT6821 is down, I'm trying to restore but when I try a repair it says on problem signature 06 "NoHardDrive". What does that mean? I can't reinstall windows because there isn't a drive to install...
ok what that is saying is the hard drive is not being reconized by the bios. you will need to go into the bios by hitting either F1 or F2 or delete . turn off computer as soon as you see it coming on hit one of the keys i mentioned. it should say entering setup.
in setup you will need to load the default settings..
look at the botom or left hand upper corner. sometimes it will be across the top. look for load default settings . select load default settings save and exit. if this fails you may need to replace the harddrive also known as ( HARD disk or HDD.
Nov 14, 2009 | Gateway MT6821 Notebook
I can not figer out how to load programs from old hard drive to new hard drive.Prestige
In most cases old HDD are not recognised by new systems.
Try installing them (if you have the original setup discs) just as you did on your old HDD
Sep 03, 2008 | Computers & Internet
Acer Extensa 5420-5687 Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
