Question about Kingston DataTraveler 101 G2
F:\ in not accessible the request could not be performed because of an I/O device error
  • Brian Sullivan
    Brian Sullivan Oct 24, 2012
    In order to get the removable disk working again, you will need to boot up your computer using the Windows installation disk and then format the corrupted drive. Connect the removable disk to your computer.Insert the Windows installation disk into your optical drive and reboot the system.Press any key on the keyboard when you see the prompt asking if you want to boot to the CD.Press "Next" and then click on the "I accept the license terms" button.Click "Custom" when the program asks you what type of installation you want to perform.Click on the "Drive options (advanced)" button. The next window will display a list of all the hard drives connected to your computer. The removable disk will appear, even if its data is inaccessible.Highlight the removable disk that you want to format and then choose the "NTFS" option. Click "OK" to clear the data and format the hard drive.
  • Kingston Master
  • 27,725 Answers
W7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you still have I/O device error
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this post a reply
sometimes you will need to restart your computer with the usb drive still inserted in your computer
hope this helps
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
Posted on Oct 24, 2012
  • 1 more comment
  • midomany
    midomany Oct 24, 2012
    thank you Brian ,but i am still have the same problem after doing all steps
  • Brian Sullivan
    which operating system and type of computer desktop or laptop and did you check the usb leads on the motherboard for dust free secure connections
  • Brian Sullivan
    Brian Sullivan Oct 29, 2012
    When you connect an external hard drive or USB flash drive to your PC computer, the drive should appear in the "Computer" window However, if the data on the drive is corrupted, you may receive an error saying that the disk is not accessible. In order to get the removable disk working again, you will need to boot up your computer using the Windows installation disk and then format the corrupted drive. Connect the removable disk to your computer.Insert the Windows installation disk into your optical drive and reboot the system.Press any key on the keyboard when you see the prompt asking if you want to boot to the CD.Press "Next" and then click on the "I accept the license terms" button.Click "Custom" when the program asks you what type of installation you want to perform.Click on the "Drive options (advanced)" button. The next window will display a list of all the hard drives connected to your computer. The removable disk will appear, even if its data is inaccessible.Highlight the removable disk that you want to format and then choose the "NTFS" option. Click "OK" to clear the data and format the hard drive.
I/O device error
Hmm? Your drive may be corrupted which makes it unuseable. I hate to admit your files may be lost at this point also. In order to reuse the unit, repartion and format the unit. I hope this helps.
Jul 14, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Unable to access music files on mp3 player
please scandisk your mp3 to fix bad sectors or errors in the system..
Jun 16, 2009 | Audio Players & Recorders
Request could not be performed because of an I/O device error
Search for a reset on the device--mine requires a paper clip to reset
Aug 27, 2008 | Audio Players & Recorders
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
OR
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
OR
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
"The request could not be performed because of an I/O device error"
if like that u just reformat your memory card with your phone..
or not u use other phone to reformat it..
May 02, 2008 | Nokia N70 Cellular Phone
Can not access device neither directly nor via PC
I have the same frigging problem with mine. What's the solution?
Mar 19, 2008 | SanDisk Sansa e140 MP3 Player
Drive is not accessible. The request cannot be performed because of an I/O Device Error
When accessing the above said error occured
Jan 26, 2007 | Matsunichi MF326 MP3 Player
Kingston DataTraveler 101 G2 Logo
2,190 people viewed this question
Top Kingston Electronics - Others Experts
Jerry Umali
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
