Question about Garden
Looking for an 18V battery for a tornado 18volt cordless chain saw, model et-2506
Battery id: ET-18V-20B
lemmingleejn
  • 173 Answers
SOURCE: Ryobi cordless chain saw leaks oil. Runs fine.
The problem is, that it doesn't require 'movement or inertia', to draw/or pump the oil.
It syphons through, naturally.
The only solution is, to not store it with oil remaining in the reservoir.
That's it I'm afraid.
There is no way, to stop it from drawing oil through, without stopping it from working correctly.
Happy, (& safe;) chopping.
& plz don't give me the thumbs up, thanks :)
Posted on Aug 01, 2009
  • 4088 Answers
SOURCE: Am I wise to purchase a Remington Pole Saw or
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
Posted on May 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I cannot find my manual
Your manual can be found here:
http://www.blackanddecker.com/Manuals.aspx with pop-ups enabled then enter your model number
or
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
See the instructions for replacing the chain on page 11. It makes reference to the figures on page 6 so that you know exactly what to remove.
Basically... loosen the bar allen screws. Remove the sprocket cover. Loosen the bar retaining bolts. Use a flat bladed screwdriver on the bar / chain tension screw to shorten the bar enough to install the chain. Then adjust the chain tensioner so that there is just a little slack in the chain at the bottom of bar between the drive sprocket and the bar. Tighten the bar retaining bolts install the cover / tighten all cover fasteners. (see details D and E page 6 of the 2nd link above.)
The steps below are copied from the manual.... I can not undo the formatting and can not post the figures here due to size restrictions..
Thanks for choosing FixYa,
Kelly
Replacing the Saw Chain
CAUTION: Sharp chain. Always wear protective gloves when
handling the chain. The chain is sharp and can cut you when it is
not running.
WARNING: Sharp moving chain. To prevent accidental
operation, insure that battery is disconnected from the tool
before performing the following operations. Failure to do this
could result in serious personal injury.
• Place the saw on a firm surface. Rotate the two allen head screws
(11) counterclockwise with the wrench (13) provided as shown in
figure E.
• To remove the saw chain (9), rotate the tension adjustment screw
(23) in the front of the housing using the flat screwdriver end of the
wrench (13) as shown in figure F. Turning the screw
counterclockwise allows the guide bar to recede and reduces the
tension on the chain so that it may be removed.
• Remove sprocket cover (10) and allen head screws (11).
• Lift the worn saw chain (9) out of the groove in the guide bar (8).
• Place new chain in groove of guide bar making sure saw teeth are
facing correct direction by matching arrow on chain with graphic on
housing shown in figure G.
• Place the saw chain and guide bar assembly around the sprocket
(19). Check to make sure that the slot (20) in the guide bar (8) is
over the two location pins (21) shown in figure E and that the hole
below the slot is located over the adjustment pin (22).
• Replace sprocket cover (10) and thread allen head screws (11) in
with wrench until snug, then back wrench off one full turn.
• Pull bar nose up and keep it up as you adjust tension.
• Rotate the tension adjustment screw (23) in the front of the housing
clockwise to increase the chain tension as in Figure F.
Follow instructions in "Adjusting Chain Tension" section.
• While still holding the bar nose up, securely tighten the rear allen
screw (11) first, then tighten the front allen screw.
• When the chain is new check the tension frequently (after
disconnecting battery) during the first 2 hours of use as a new chain
stretches slightly.
not running.
• With the saw still on a firm surface check the chain tension. The
tension is correct when the chain snaps back after being pulled
1/8 inch (3mm) away from the guide bar (8) with light force from the
middle finger and thumb as shown in figure H. There should be no
"sag" between the guide bar and the chain on the underside as
shown in figure I.
• To adjust saw chain tension, loosen the allen head screws (11).
using the flat screwdriver end of the wrench (13) as shown in
figure F.
• Do not over-tension the chain as this will lead to excessive wear
and will reduce the life of the bar and chain. Overtensioning also
reduces the amount of cuts you will get per battery charge.
• Once chain tension is correct, tighten allen head screws (11).
stretches slightly.
Posted on Nov 08, 2010
  • 252 Answers
SOURCE: I do not have a
You should be able to remove the cover at the adjustment screw..........First back the screw out at about half way....then remove 2 nuts remove cover........Pull blade ....it should slide with chain attached to snug chain ....Then reinstall cover and nuts and re adjust....This is how mine is done but you have to remove cover to loosen blade so you can slide it to tighten chain and reset the adjustment screw...................Hope this helps...............................Metalpoet
Posted on Mar 08, 2011
Testimonial: "Your suggestions worked, thank you.. I love my little saw; never that a problem with it...It is great for trimming small branches and brushes "
  • 5 Answers
SOURCE: I just bought a Ryobi
Man, I know what you mean. If I am not going to use my saw, I empty my saw oil back into
the oil bottle using a large funnel to catch it all. Then I can put the saw in a large cardboard box
lined w/layers of newspaper in an upright position til next time. Works great! Get back to me if
you need help sharpening that puppie...............dansky66
Posted on Mar 27, 2011
Where can I purchase a replacement battery & charger for a tornado cordless pole saw
Try searching for a battery pack rebuilder in your area.
They will look at the current cells in your battery pack and try to find suitable replacements of the same size and amperage
Nov 10, 2017 | Televison & Video
I would like to buy (2) Rechargable ET18V-20B batteries that will fit my TURNADO ET-2506 portable chainsaw. Your help would be appreciated ! Phillip Silva
I honestly think you'd be better off replacing the chainsaw than trying to find batteries for it.
But, All Battery com Rechargeable Batteries Chargers can sell you materials to rebuild your dead ones, rebuild them for you or they might even have a generic in stock that will fit. I've recommended them in the past for some rather esoteric battery needs and they've always come through.
Apr 03, 2015 | Miscellaneous
I have a Tornado cordless chain saw. I have lost user guide. How do I oil this chain saw?
Google on line and ask for a user manual giving the name, product model number of equipment you are in need of an instruction guide.
Apr 03, 2011 | Tornado CW50 - 91450 Bagged Upright Vacuum
DEWALT DW938 18VOLT CORDLESS SAWZALL can it use Lithium Batteries
As long as the voltage of the battery is the same as the tool, the tool won't mind if the power is coming from a NiCd or lithium battery. You do have to have a charger that works with lithium batteries to charge them up. Chargers that can charge lithium batteries can also charge NiCd and NMH batteies. NiCd chargers are not always programmed to detect when lithium batteries are full and may continue to charge them to the point of melting or starting on fire.
Jan 31, 2011 | Dewalt Dw938 18v Cordless Reciprocating...
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Where can i get a coleman powermate 18v power supply for a cordless drill?
I'm looking for an 18volt batterie transformer for my coleman powermate drill, my transformer stopped working, and can't find one.
Thank You
Douglas Jonatzke
sjonatzke1@verizon.net
Sep 25, 2009 | Drills
Garden Logo
799 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
