I had to reinstall video pro 3x and now I cant open my previous projects
    Scholar:
  • 106 Answers
Dear Donna,
Obviously you might have saved your projects in a folder other than the default Corel Video Pro X3 folder. Even, if they are there on uninstalling the software asks for deleting user data. If they were there and you had deleted the user data than you shall need a File Recovery tool to get your files back.
Second:
If they are not in the default folder and projects files are still there on your system, you can easily double click and open them again in Videostudio X3. Once, you have uninstalled the s/w and then installed it back the Recently Open/Projects list is deleted by default. Once, you shall start opening your projects again and again the list shall compile again.
Posted on Oct 24, 2012
Magix Movie Edit Pro Premium 2015 cannot find or recognize many of my saved MVP Project files. All previous saved project files still show in MEP 2015 folder. How do I get MEP 2015 to open them?
Magix software can be fickle at times. All I can suggest is that you are very careful with files and directories associated with the working files of the software. One tiny change will produce a file not found response. You can sometimes manually take it the missing file, but it's messy.
I suggest that any outputted files are not directly changed, but left where they are. If you want to do with something afterwards create a new folder and copy the files you want into that folder. Then change those files.
If you look at the original files that you worked on, you will see around four files near it. Deleting any of these files will produce that response. If you alter any of the original files you worked, you will get the same response. Because the Magix files around it will no longer match with the file you altered.
Sep 23, 2015 | Magix Computers & Internet
How can I recover my Corel Video Studio Pro 3X projects?
Please could you identify how you end up losing them in detail.
Oct 24, 2012 | Corel VideoStudio Pro X3
How to use adobe premiere pro 2
Adobe premiere pro is software for video producers that takes you from the start to completion of your video project. You will run into less conflict working with other video formats due to the "Native Editing Support" from "SD" to "HD" that is provided in this software. A convenience is that every workspace has a separate panel and when using multiple panels they can be docked where you want.
Please follow the below step.
Step 1: Open the premiere software and choose which project you will be working with, either a previous, recent or new project. No need to change the default settings at this time.
Step 2: Go to the "Capture Format" menu and choose the type of format you want to capture, for example from the web or a dvd. (http://www.ehow.com/internet/)
Step 3: In the dialog box at the bottom give your project a name and determine the folder you are going to use to save your project. Before you click OK, select the "Scratch Disks" tab to create your own folder structure, this will make it easy when it comes time for you to move the media and archive. Now choose the folders you want to store the captured media you identified in step 2 and when you are ready, click "OK."
Step 4: Work with your sequences in the "Workspace Layout." This area is divided into sections, the top left and middle contain the project panel, source monitor and effect controls. The top right of the workspace contain the audio mixer and program monitor. The left lower section contains the media browser, info panel, effect panel, sequence and history panel. The bottom right panel contains the tracks, time-line, clips and audio meter.
Step 5: Edit your sequences using the "Timline Panel." Each sequence you add will appear as a tab within the "Timeline Panel." You are not limited to the amount of sequences you create or number of timelines you open.
Step 6: Create your video and audio using the "Tracks" feature. Each clip you add to the sequence needs to have a track identified. This is where you are adding sound to your sequences within your "Timeline Panels."
Step 7: Trim your clips using the "Source Monitor." Here you can add or remove a sequence by double clicking on the clip in the "Project Panel." You can then play back the clips in the sequence you assembled to view your project.
Step 8: Access the "Project Panel" and "Media Browser" for links to the different aspects of your video project when you need to add, change or remove sequences. When you are ready, go to the "Effects Panel" and begin setting the desired effects to the sequences you created.
Step 9: Open your "Tools Panel," which provide shortcuts on the keyboard for several of the functions mentioned in earlier steps. This is the beginning steps in using adobe premiere pro, to continue to the end of your video/media creating follow the prompts.
Thanking you
davevipul197
Jun 02, 2011 | Adobe Computers & Internet
When I open my sony vegas 9 project, it begins to load, but when it reaches 17% a pop up comes on with the following messege: "An error occured while loading the project back to chernowitz.veg. The file...
The file is most likely corrupt. I would recommend trying to reinstall Sony Vegas Pro if the problem persists. If you are trying to open a file within Sony Vegas Pro then i would recommend searching or asking for ways to fix the corrupted file format, however their are plenty of good file fixers online.
Aug 13, 2010 | Sony Vegas Pro 8 for PC (SVDVD8006)
After One Month Corel Video Studio Pro X2 is not open, I Can't open this softwaer.
Uninstall it first and clean the registries using ccleaner (freeware) & reinstall again.
Feb 25, 2010 | Corel Video Studio Pro X2 for PC
Quickbooks pro 2005 I cant open my backup files
You are not able to open a backup file in Quickbooks, Only restore it, to open a previous backup, the easiest way is to make a copy of your current company file, then restore the backup over it. This will give you a company file with the backup data.
Nov 23, 2009 | Intuit QuickBooks: Pro 2005 for PC
NB100 fatal error while upgrading xp home to xp pro - pls. help
Hi
Try to go into System BIOS. Once you are in use the option Load Defalut settings.
And if any external device is connected other than CD-ROM, please disconnect it.
THEN TRY AGAIN TO INSTALL
Aug 03, 2009 | Computers & Internet
Acrobat 7.1 shuts down after opening
Installing later version of Adobe Acrobat is sometime creating compatibility issue with previous installed Adobe Acrobat Pro.
Make a deep search for your condition on Adobe KB: for similar problem I had to Reinstall Adobe Pro AFTER an update of Reader free Sw.
Check this entry
Dec 29, 2008 | Adobe Acrobat 6.0 Professional for PC
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
