My Amplifier is humming
My Amplifier humms
  • 5,807 Answers
My amplifier hums.
If it is really the amplifier that makes a humming noise check on the
power transformer.
But if your referring to humming produced on your speaker then
check on it, not good to turn On for long.
First check for DC offset, use a multimeter.
If there are more than 0.7V on the output, have a tech to repair
your main amplifier.
If it is about 0.7V, then check the preamp circuits and power supply
filtering circuits and regulators.
Posted on Oct 24, 2012
    New Friend:
Make sure all your mic inputs are turned all the way down. I left them up once and It was humming really badly and I had no idea why....
Posted on Aug 07, 2013
2 Suggested Answers
  • 6 Answers
SOURCE: amplifier is humming
amplifier is voltage given throuh any high voltage
I have a frigid air gallery series washer that lights up and just humms,it will not start cycle. I have checked pump and motor isn't ether one of those making humm sound
Good Afternoon Cloy,
I understand that you are getting a humming sound on your Frigidaire washer, and it will not start a cycle. I also see that you've checked the pump as well as the motor, and neither of those is making the humming sound. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine what is causing your appliance to make that humming sound and not run a cycle. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Washing Machines
The hums are probably the fan kicking in to keep it cool.
Jan 25, 2013 | Audio Players & Recorders
Oct 24, 2012 | Audio Players & Recorders
I get a humming sound when the ipod is attached,
the hum comes from three possible sources, the power unit can cause it before failure, the amplifier which can effect one or more speakers or the interface board between the other two, the interface board and the power board are known problems to b and w, so if you have not already contacted service at b and w, then do so.
May 15, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Bad Humm out
First disconnect all inputs. If hum is still there, PROBABLY the filter capacitors have gone bad. Replacement is the cure.
IF there is no hum without any inpout cable connected, there is a ground loop and either the ground at the inout connector is broken, or your cables and guitar may have a problem.
Nov 15, 2009 | Marshall Amplification Marshall MG250DFX...
Sub has started humming with amp turned off. just turned on at wall switch.nothing running
If the hum is from the back of the unit around the amplifier, it may be the transformer. It could be that the mounting is loose.
It could also be that the transformer is going out.
Disconnect all the inputs to the unit, Still hum?
If the hum stops you have something causing noise to the input.
If you have it on a switched circuit, try moving the power plug to a different outlet that is not on a switch. If hum stops, then you have something on that circuit causing the problem
if all inputs are disconnected and it still humms good chance it is the transformer.
Nov 12, 2009 | Velodyne CHT-8 Subwoofer
I have a loud humm in my bose lifestyle 28 system
Turn on your bose so you can hear it hum. Go to the back of your cable box and remove the co ax cable connected to "cable in". If the humming stops, the sheilding on your cable is no longer grounded. Purchase MPAV800 or similar surge protector to run cable line through it and get it grounded.
Feb 02, 2009 | Bose Lifestyle 28 System
Humm
where is the ground wire from the turntable connected to ? Ensure that is is connected to the phono pre-amp's ground.
Is the turntable sitting on top/near any other equipment ? Try changing the position and see if the hum reduces. If yes, then it is likely that it is picking up hum from a mains transformer.
Aug 21, 2008 | Aiwa PX-E860 Turntable
Fan
The hum is power line hum ( 60 cycle ) . It may be that when the amp gets warm that something in the case wants to vibrate to the 60 cycle hum.
I have amps that hum like that and theyre fine.
Depending on the design of the amp, the cooling fan may not go on till it gets really warm in the amp. Some run all the time like the Ashly I just fixed
Dec 03, 2007 | Crown CE2000 2-Channel Amplifier
537 people viewed this question
 Grubhead
Grubhead
