Question about Canon PIXMA MG6220 Multifunction Printer - Color- 20 Second Photo 9600
Win 7 64bit will not recognize mg6220 printer scanner
Wont install in win 7, system says it is unplugged fro usb port
  • 3 Answers
Try getting a different usb cable,also try a different usb port
Posted on Oct 24, 2012
CODE 43 WHEN CONNECTED
This is usually because the disc control board in the External drive has failed, Try it in a different portable case.
Sep 14, 2012 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
I have connected my 4Gb Usb Device to my PC, But
insert the usb drive
if a notification bubble appears click it
a dialog box appears showing the new hardware found
click on the detect automatically button.
it starts searching..
if the driver is in r system it installs
if not download the driver from net
write the device model number and company
check ur usb port......
try using in ur friends computer
Mar 11, 2010 | HHP ImageTeam 4710 Barcode Scanner
USB not recognized during printing and scanning
Some motherboard or operating systems have problems if you leave usb devices plugged in. They don't recognize that the device is still there and ignore it. These are referred to as "Legacy USB devices". There are a couple of things to try.
Make sure the problem isn't the printer if you can. If you have another computer just plug it in long enough to for the operating system to recognize something has been plugged in.
On this computer giving you the problem. unplug the usb cable and insert into a different USB port. Usually this is enough to "fix" it and make it usable.
Next is to unplug the usb and reboot the computer a few times. Then insert into a different usb port.
Past this point if it still isn't working then you need to go to control panel-system-hardware manager-usb devices and delete all entries under the usb header. Then reboot. This forces the operating system to find all the usb ports and reinstalls the drivers. Then plug in the usb and it should work again.
Oct 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Computer can't "see" scanner even though plugged into USB port
please check:
if other usb-devices work with your pc, so usb ports of your machine are ok.
try connecting the printer to another machine, using same procedure as u did with the old one
did you get any installation cd with it?
any newer drivers for your win-system available?( inet, manufacturers homepage)
if your system and the printer passed the hardware check, install newer drivers and try again.
wish u luck
Jun 18, 2009 | Ambir Technology DocketPort 485
Need vista operating system driver 1200 UB Plus USB Port Scanner
According to the manufacturer this product is not compatible with Windows Vista. There are no drivers available for this reason. Sorry.
Jun 03, 2009 | Mustek ScanExpress 1200 Flatbed Scanner
Installed the scanner program for bjc-80 onto a Netbook with only USB ports...wont recognize printer/scanner,,,help
Netbooks usually doesn't have PCMCIA capability. what you sould do is to disable the bidirectional function of the printer. To disable the bidirectional support You have to open the printers properties. In the "printers and faxes" map, right click on the printer and choose properties. then on the "Ports" tab, down below there is a tick mark choice with some text like: "Enable bi-directional support " you have to clear the tick mark!
Apr 25, 2009 | Canon BJC 80 InkJet Printer
Hp photosmart 2610xi does not scan.
Remove all hp software and drivers from control panel>add remove programs. Then go to control panel>system and go to hardware and then device manager, then delete your printer/scanner from the list by right clicking and 'uninstall'. Then restart, and make sure you printer/scanner is unplugged and off. Then once your computer restarts go to hp's website and make sure you selected the right country (at the top), then go to support & drivers and download the software/drivers that are for your printer/scanner. Once drivers/software is install, then connect printer (or follow installation instructions, if different)
Also, just to make sure, plug it in a different USB port (after the reinstallation) incase the old drivers are stuck on the computer somewhere. Drivers usually/sometimes are associated with a specific usb port and will reinstall when plugged in a different port.
Mar 07, 2009 | HP Photosmart 2610xi All-In-One InkJet...
HP 1210 c/ps will not print
you will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
good luck
Nov 22, 2008 | Microsoft Windows 98 for PC
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Scanner not being recognized
Knowing your PC-System would be helpful: Is it Win (and what version) or is it Mac?).
Did you connect to a USB-hub? This wont work! You have to connect directly to a USB-port of your PC.
Do connect only by a USB-cable NO longer than 2-3m!
Jan 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MG6220 Multifunction Printer - Color- 20 Second Photo 9600 Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
