How do I change my Toshiba bbe tv to aux/video with my RCA remote that's already programmed to the tv its self?
5 Suggested Answers
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
  • 105 Answers
SOURCE: programming a remote
You should have instructions that came with your new remote that show you how to program specific buttons to specific functions. In general there is a similar button on universal remotes, it may be called input or some other button that implies changing the video source.
Good Luck
Posted on May 23, 2008
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Posted on Sep 12, 2008
SpotBert
  • 231 Answers
SOURCE: Programming a remote
Here's the RCR450 Manual =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Toshiba TV are Toshiba 1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241 and are listed in back of the manual.
Posted on Dec 31, 2008
I have a toshiba tv it's not a flat screen but its
If your universal remote has a video source select function, you should be able to use that as the aux(iliary) mode
Sep 07, 2013 | Televison & Video
I need a code for a RCA universal remote and a SEARS tv.
RCA
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Mar 13, 2011 | RCA Televison & Video
Program my remote
Please follow the below steps to set up your programme
Direct Code Entry:
  1. Find the code your device.
  4. Enter the 3-digit code number.
  5. Release "CODE SEARCH".
  6. With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5.
Code Search:
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed(VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 24, 2010 | RCA Universal Remote Control
Don't have manual - have taken the batteries out, don't know how to enter codes. wont even turn on or off.
Hi
Please
device to be programmed (VCR,TV)
Thanx
Jul 22, 2010 | RCA RCR350 Remote Control
RCR460 Remote Control: I need to know how to program my rcr 461 to my tv....
Direct Code Entry:
Code Search:
Please
Thanx
May 16, 2010 | RCA RCR460 Remote Control
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Sep 07, 2009 | RCA Universal Remote Control
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
RCA REMOTE CODE
Jun 22, 2008 | RCA Universal Remote Control
Programming rca universal remote for my toshiba tv
Apr 03, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
