Question about GPX Td2420Ab 24" 1080P Lcd HDTV - DVD Combination 047323824104
POWER SUPPLY CARD ASSEMBLY FOR GPX TV/DVD COMBO
Need replacement power supply assembly TV will not power up and there's no fuses to change and board looks burnt
5 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: can you help me find a schematic dtagram for GPX CDRW3500?
Ask the schematic finding experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
SD Tech
  • 14553 Answers
SOURCE: my GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Posted on Mar 14, 2012
gopakumarg43
  • 75581 Answers
SOURCE: Need a remote code for comcast dta to work with my GPX TDE1380 tv dvd combo
There is no setup codes for GPX with Comcast DTA remote control.
Posted on Apr 24, 2012
  • 13 Answers
SOURCE: gpx td3222 dvd stuck
tweezers...
Str z-4517 in power supply bad
There should be a reason for this fault. First, check for it. In most cases, replacement of power supply board as card basis is recommended. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 22, 2014 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
06 srx sunroof doesnt work
Sorry Bill but you don't the tool's or knowledge to take on this job . Control module's involved.
Which one does your vehicle have ?
Power Sunroof System Components -- CF5
The power sunroof system consists of the following components:
• Front glass control module and motor assembly
• Front sunshade control module and motor assembly
• Sunroof switch
• Front glass panel
• Front sunshade
• Power supply for the front glass control module and motor assembly logic: RAP relay
• Power supply for the power sunroof system: SUNROOF MOD fuse 40 A
Power Sunroof System Components -- C3B
• Sunroof switch
• Front glass panel
• Front sunshade
• Rear sunshade control module and motor assembly
• Rear sunshade switch
• Rear sunshade
• Rear fixed glass panel
Aug 30, 2017 | 2006 Cadillac SRX
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
When u push the power button the tv tries to turn on, makes 3 switch noises and then the power turns off
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Dec 20, 2009 | RCA D52W136D 52 in. TV/DVD Combo
Image source 50 code E64
E064 Error code details Power supply voltage error (high-voltage error)
0000 The presence of a high-voltage error is communicated by the composite power supply PCB.
(The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Main cause
 The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
 Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
 YES: Clean the contact, and set it once again.
2. Wiring
 Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
 a. DC controller PCB (J301) <-> composite power supply PCB (J136)
 b. composite power supply PCB (J130-7) <-> primary charging roller contact
 c. composite power supply PCB (J130-1) <-> developing assembly contact
 d. composite power supply PCB (FT133) <-> transfer roller contact
 NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
 Try replacing the composite power supply PCB. Is the problem corrected?
 YES: Yes.
 NO: Replace the DC controller PCB. pls rate for my good deed!!!!!!!!Good Luck
Sep 21, 2009 | Office Equipment & Supplies
GPX Td2420Ab 24" 1080P Lcd HDTV - DVD Combination 047323824104 Logo
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
